But will it still work with conversDGAlexandru wrote: ↑26 Oct 2021, 07:17EDU Mini is too miniGwe89 wrote: ↑24 Oct 2021, 13:07 https://www.digikey.co.uk/en/products/d ... DCEALw_wcB
What about these?
You can't go to a more powerfull version.. whatever the unlocking codes you give it... as it is different hardware, with less processing power.
J-link
Re: J-link
Re: J-link
I got the mini connected all up with a logic converter as it's 3.3v and just get errors looks like I will be better off buying the bigger unit
Re: J-link
I can now dump convers and now trying to erase chip and reflash I think I broken it
won't do anything now
DGAlexandru
- Pro
Re: J-link
Your JTAG connection is not stable enough.
There are also some tunning parameters you should try to add to the initialisation sequence.
See the JTAG settings for OMAP - the MCU for BP NX Navigation and go from there... or maybe there are also JTAG settings already available on this forum for MAC7116 of Convers+
Re: J-link
Thanks set the init to auto detect and now it works, my bench convers 29seconds to flash maimDGAlexandru wrote: ↑03 Nov 2021, 05:58 Your JTAG connection is not stable enough.
MODA MODB can anyone explain how we use these in more detail, I put vcc to MODA which allows me to erase the selected sectors and then after a switch off and on of the convers allows me to flash the main, but on the one m0tral has (locked up?) It won't let jtag talk to it anymore I'm wondering if I have to do something different with MODA MODB
DGAlexandru
- Pro
Re: J-link
Those pins dictate how MAC7116 uses its internal and external memory and which of them are in protected mode.. or something like this. Their operating modes are described in MAC711x family PDF... you can find it also here on this forum.
Re: J-link
ThanksDGAlexandru wrote: ↑03 Nov 2021, 20:23 Those pins dictate how MAC7116 uses its internal and external memory and which of them are in protected mode.. or something like this. Their operating modes are described in MAC711x family PDF... you can find it also here on this forum.
Managed to fix my convers, selected unprotect chip and now allowed me to flash whole new file with a stock PBL got rid of m0trals new edited PBL now I have full control of my ipc again, comparing between stock PBL and m0trals PBL there is alot differences
DGAlexandru
- Pro
Re: J-link
There are at least 3 original PBL versions.
They look very different but putting a FaceLift one on a PreFaceLift Convers+ I couldn't observe any problem in its normal operating mode.
May you share with us this PBL, please?
Re: J-link
As DHAlexandru said, those pins control the setup of the MCU: I marked the green one as the default operation mode. The onboard-flash is NOT protected and MODA and MODB are LOW (0) because they are tied to GND due to resistors on the board. So applying +3.3V to them from the CPU Vcc lines can bring them into a desired state.DGAlexandru wrote: ↑03 Nov 2021, 20:23 Those pins dictate how MAC7116 uses its internal and external memory and which of them are in protected mode.. or something like this. Their operating modes are described in MAC711x family PDF... you can find it also here on this forum.
steveb has made a small backup-pcb where he added a DIP switch to change those lines as needed, cool idea.
You may read my post here where it all is explained in detail: viewtopic.php?t=30
