V1.0.0
Not everything works as I didn't find yet all the needed CAN messages.
Outside Temp worked very well on OEM FW for FaceLift version, but on the M0 tr al one it doesn't. On PreFaceLift it works without any problem.
Tested with ELS27 (original and clone); also tested with other ELM327 China versions.
As long as your adapter supports at least 115200 baud it will be able to do the job.
Just be careful to select the right version when you are asked to do so.
I've also implemented a Send CCC function to reconfigure Convers+ with all the features it is capable of. In the future it will have the option to select a file that contains CCC data. I've added the config also in a separate file - CCC.elm in order to see it with ELMConfig (Offline - Mondeo 4 - CCC - Load from File).
For now it doesn't setup a VIN by CAN, but it is on the list.
Did anyone managed to play with the needed CAN messages for Dimming control? I couldn't find the right bytes. I think it also looks at other values from other CAN IDs.
Open it, press Run.. before exiting press Sleep and wait for program to close CAN connection - just not to give you errors that it didn't manage to stop all its threads (workers).
Oil Lamp gives "Engine Malfunction Message" as I couldn't find it either.
To access Parking Mode you have to select Reverse
![Smile :)](./images/smilies/icon_e_smile.gif)
For now there isn't any other working option for simulating the Gearbox as this one also plays hard to get.
Standard password.. this version is for free.. even if I didn't get the help I needed.
![Crying or Very Sad :cry:](./images/smilies/icon_cry.gif)
