hi can any one help me with the SBL file for the blis module for Mondeo/Galaxy/Smax
Please
Thank you
I think these blind spot modules come under
SODR and SODL in ucds
Blis
Re: Blis
I do not have both at hand, latest two i bought are already inside my car
But as they are sealed/glued it is not easy to compare the boards.
I don't think they are different on the boards... or better say, i can't imagine that they differ.
Re: Blis
It was pretty easy to teardown, sharp stanley knife around the edge of the case (not hard sealed) and cover pops off, rework Station to heat the solder joints and carefully leaver out, the pins on the housing are built into it, i will get some better pictures to identify parts
DGAlexandru
- Pro
Re: Blis
Yes, TMS740 is the core processor - here we have the "calibration" files.
ADSP-BF531 is a "BlackFin" processor which seems to be used mostly in multinedia systems.
https://www.analog.com/media/jp/technic ... 533_jp.pdf
Put here the txt part of the VBFs you used in order to see at what addresses it writes those bytes and see if rewrites the whole TMS740 flash space or there are zones left untouched.
