hahahah!
i think i can only brick the clone if i use the 2.xxx software because the internet on the 1.26 is turned off... is that true or i can brick both lol
Ucds
- Pro
Re: Ucds
Yes, mainly you can only brick the clone one if you try to use it with newer versions of software.
I don't know of any "Internet off" feature for 1.26 version. If you are connected to Internet and run 1.26 it will tell you that there is a newer version, it will try to download the calibration files that it misses.. so it isn't "offline".
