User avatar
Stevebe
Pro
Post by Stevebe »
would you use the j tag port to load the files or use can bus
Digimod
Pro
Post by Go4IT »
Stevebe wrote: ↑25 Mar 2019, 19:06 would you use the j tag port to load the files or use can bus
This can/should be done over CAN-Bus. JTAG is dangerous, because the MAC-chip has something like an "intrusion detection an lockdown" mechanism. If you try to access the RAM/Flash via JTAG it locks itself down and can never be recovered. I killed a Convers this way myself :-( It can only be overwritten if you have the bootstrap sources, which are not inside the update files.
Gwe89
Pro
Post by Gwe89 »
Have you guys got the VBF tool?
User avatar
Ursadon
Active member
Post by Ursadon »
Gwe89 wrote: ↑01 Apr 2019, 11:11 Have you guys got the VBF tool?
I don't have it. But the vbf format is very simple:
N bytes - Header until "}" symbol
[4 byte — address block1]
[4 byte — length block1]
[x byte — data block1]
[2 byte — CRC16 CCITT of block1]
[4 byte — address block3]
[4 byte — length block3]
[x byte — data block3]
[2 byte — CRC16 CCITT of block3]
So you can easy extract .bin from .vbf using any HEX editor
User avatar
Ursadon
Active member
Post by Ursadon »
Go4IT wrote: ↑25 Mar 2019, 06:14 I have a UCDS and also had captured the CAN comms of updating an IPC with new firmware. I will provide that log here, maybe it‘s of some use for you... but there are parts regarding random seed which are useless to replay, i guess, but give it a try.
It would be nice if you provide can dump of fw update. I think, that seed is predefined. Maybe 20-30 variants of keys :)
Pro
Post by Go4IT »
Ursadon wrote: ↑01 Apr 2019, 12:01 So you can easy extract .bin from .vbf using any HEX editor
Right, do it all the time because those dammned VBF tool will only export as HEX or S19 and not directly to BIN.
I also had documented this in the Wiki https://mk4-wiki.denkdose.de/en/artikel/vbf/start
Pro
Post by Go4IT »
Ursadon wrote: ↑01 Apr 2019, 12:07 It would be nice if you provide can dump of fw update. I think, that seed is predefined. Maybe 20-30 variants of keys :)
I would instantly, but i can't find the log i made a while ago and now i currently have no working Convers to play with :-(
Hopefully i get the one i lent back, or i need to buy another one...
But the update scheme will be the same for other modules?! So if i capture any update, would it be sufficient?
Gwe89
Pro
Post by Gwe89 »
Well I have vbf tool if its any use to you
User avatar
Ursadon
Active member
Post by Ursadon »
Go4IT wrote: ↑01 Apr 2019, 13:13
I have a dump for PAM, but I think the procedure for IPC is a bit different.
Also, the last 4 bytes in external flash is not a CRC32. I tried to bruteforce it by reveng uility (http://reveng.sourceforge.net/) but no luck.
Pro
Post by Go4IT »
I dunno nothing about CRC calcs. Awesome infos on link, thanks!
For the Update-Thing, i opened another thread.
Post Reply
