Have you seen a version of vbf tool 2.3.
Update IPC
Re: Update IPC
No, but the original and recent files are version VBF 2.3. The older version is in the header version 2.2...
I meant vbf version not vbf tool.
Re: Update IPC
As VBF format is an ever upcomming question, let's use the wiki to document all the experience and tools! https://mk4-wiki.denkdose.de/en/artikel/vbf/start
I try to add as much as possible there, but please point out what was missing.
oscarboiro
- Active member
Re: Update IPC
Hello, i try in my Arduino skect and work fine, in my kuga 1 need the key: (A8, 0, AF, 91, 24)Ursadon wrote: ↑25 May 2019, 16:38Hi! I apologize for the delay - I finished my studies at the instituteoscarboiro wrote: ↑30 Apr 2019, 08:49
After copy on my arduino sketch have this error: expected initializer before 'LFSR'
i need a LFSR library? the code are only to C# or is valid to arduino?
This is pseudo C code
Here is C code, which you can use - https://gist.github.com/Ursadon/8c55972 ... efa037fabb
Also:
1) I cracked all secret keys for (probably) all modules in Ford - https://gist.github.com/Ursadon/8941ff5 ... e09f060eec
For IPC use second key.
2) I made my own CANhacker, so the development process will go faster![]()
But im programming a tool to update my intrument cluster in a visual basic.
i try to convert the C code to visual basic, bit calculate a wrog code, i use this:
Code: Select all
Private Function generate_seed_response(ByVal s1 As Integer, ByVal s2 As Integer, ByVal s3 As Integer, ByVal s4 As Integer, ByVal s5 As Integer, ByVal seed As Integer) As Integer
Dim Or_ed_seed As Integer
Or_ed_seed = ((seed And &HFF0000) >> 16) Or (seed And &HFF00) Or (s1 << 24) Or (seed And &HFF) << 16
Dim mucked_value As UInt32 = &HC541A9
Dim a_bit, v9, v8, v10, v11, v12, v13, v14 As UInt32
For i As Int32 = 0 To 32 - 1
a_bit = ((Or_ed_seed >> i) And 1 Xor mucked_value And 1) << 23
v8 = v9 = v10 = (a_bit) Or (mucked_value >> 1)
mucked_value = v10 And &HEF6FD7 Or
((((v9 And &H100000) >> 20) Xor ((v8 And &H800000) >> 23)) << 20) Or
(((((mucked_value >> 1) And &H8000) >> 15) Xor ((v8 And &H800000) >> 23)) << 15) Or
(((((mucked_value >> 1) And &H1000) >> 12) Xor ((v8 And &H800000) >> 23)) << 12) Or
32 * ((((mucked_value >> 1) And &H20) >> 5) Xor ((v8 And &H800000) >> 23)) Or
8 * ((((mucked_value >> 1) And 8) >> 3) Xor ((v8 And &H800000) >> 23))
Next
For j As Integer = 0 To 32 - 1
v11 = ((((s5 << 24) Or (s4 << 16) Or s2 Or (s3 << 8)) >> j) And 1 Xor mucked_value And 1) << 23
v12 = v11 Or (mucked_value >> 1)
v13 = v11 Or (mucked_value >> 1)
v14 = v11 Or (mucked_value >> 1)
mucked_value = v14 And &HEF6FD7 Or
((((v13 And &H100000) >> 20) Xor ((v12 And &H800000) >> 23)) << 20) Or
(((((mucked_value >> 1) And &H8000) >> 15) Xor ((v12 And &H800000) >> 23)) << 15) Or
(((((mucked_value >> 1) And &H1000) >> 12) Xor ((v12 And &H800000) >> 23)) << 12) Or
32 * ((((mucked_value >> 1) And &H20) >> 5) Xor ((v12 And &H800000) >> 23)) Or
8 * ((((mucked_value >> 1) And 8) >> 3) Xor ((v12 And &H800000) >> 23))
Next
Return ((mucked_value And &HF0000) >> 16) Or 16 * (mucked_value And &HF) Or ((((mucked_value And &HF00000) >> 20) Or ((mucked_value And &HF000) >> 8)) << 8) Or ((mucked_value And &HFF0) >> 4 << 16)
End FunctionKuga MK1 owner
oscarboiro
- Active member
Re: Update IPC
i found the problem in source code of visual basic:
i need write the v8, v9 and v10 separatly
I run a test aplication and work fine
Thank you Urdason!!! if you want copy the visual basic source code in your github account!!!
my next steep is write my IC
Code: Select all
v8 = (a_bit) Or (mucked_value >> 1)
v9 = (a_bit) Or (mucked_value >> 1)
v10 = (a_bit) Or (mucked_value >> 1)Code: Select all
Next
Next
End Functionmy next steep is write my IC
Kuga MK1 owner
oscarboiro
- Active member
Re: Update IPC
i start to program my own software to update Kuga MK1 IPC, im usin a genuine ELS27, but after set up AT and ST comands y try to write, my problem comes when i write SBL or Firmware, the serial port return "STOPPED" i read a data sheet of ELM327, and some times the problem comes when write the serial port before received ">" bit if i program delay have same problem, anther probles is, when 1 send some lines, ej: 20, 21, 22, 23 only write 20, 22 ....
to solve this probles i write a blanc line, but to write all instrument cluster need 18 minutes and if i use elmconfig need only 4.
any suggestion to write my ic? i need program any especific AT or ST comand? i need write any prompt or similar?
thanks
thanks
Kuga MK1 owner
DGAlexandru
- Pro
Re: Update IPC
You can use ElmConfig to sniff their way of doing this - press the "Log" button then check "Full Information" and then check "Write to file" and choose a file.
This way you'll get all the info you need. You can stop the process after the SBL was sent.. if you don't want to wait for the full writing process to end.
Code: Select all
< AT L0
> AT L0
> OK
< AT E0
> AT E0
> OK
< AT H0
> OK
< AT S1
> OK
< AT D0
> OK
< AT AT0
> OK
< AT ST40
> OK
< AT TP6
> OK
< AT SH720
> OK
< AT AL
> OK
< AT CAF0
> OK
< 720 03 22 E6 10 00 00 00 00
> CAN ERROR
< AT WS
> ELM327 v1.4a
oscarboiro
- Active member
Re: Update IPC
Good morningDGAlexandru wrote: ↑14 Feb 2020, 07:43 You can use ElmConfig to sniff their way of doing this - press the "Log" button then check "Full Information" and then check "Write to file" and choose a file.
elm_fullInfo.jpgCode: Select all
< AT L0 > AT L0 > OK < AT E0 > AT E0 > OK < AT H0 > OK < AT S1 > OK < AT D0 > OK < AT AT0 > OK < AT ST40 > OK < AT TP6 > OK < AT SH720 > OK < AT AL > OK < AT CAF0 > OK < 720 03 22 E6 10 00 00 00 00 > CAN ERROR < AT WS > ELM327 v1.4a
I look this option and I have same configuration, but in my software don’t run with same speed.
My software are written in Visual Basic and to send commands need use a serialwrite commmand, example:
Serialwrite(“03 22 E6 10 00 00 00 00” & vbcr)
But if I send another can string need waith very long time or causes a STOPPED message.en need write in serial next:
Serialwrite(“ ” & vbcr)
And I don’t now why. If I sniff with ucds my software and elmconfig show same strings with speed difference
Kuga MK1 owner
Re: Update IPC
Linending or lenght wrong
Not native English speaker
