webasto can bus death
marekrbk
Active member
Post by marekrbk »
need webasto eeprom from webast thermo top v original ford
low battery, then write incorrectly with the program Forscan Beta 2.4.0 module kalibration ubdate
marekrbk
Active member
Re: webasto can bus death
Post by marekrbk »
a full dump is needed to fix it, not just eeprom
Pro
Post by Go4IT »
I know you need something different, but here is the EEPROM of my spareboard.
Tomorrow i could try if UCDS will see and update the board...
As there is an MC9S12DG256 on it (no external Flash or EEPROM) there may be good chance to get it downloaded via BDM as steveb did for the PAM!
marekrbk
Active member
Post by marekrbk »
Go4IT Can you download at Motorola firmware? and bad checksum need from 0 - 1680
Pro
Post by Go4IT »
No, currently not, but i'm working on it. It seems that BDM is not nearly as complicated or expensive than it seems to be. I'll be back with more detail soon...
User avatar
Stevebe
Pro
Post by Stevebe »
Go4IT wrote: 04 Feb 2020, 21:31 I know you need something different, but here is the EEPROM of my spareboard.
I would gladly download the data if I had a unit,I did look on eBay for a 6g9n-18k463-bs 32267242 unit, but they asking to much ..
If anyone has a unit in UK if they can loan me the unit I will give it go,
Digimod
marekrbk
Active member
Post by marekrbk »
we do not have the possibility of recovery of dead modules?
User avatar
Stevebe
Pro
Post by Stevebe »
marekrbk wrote: 07 Feb 2020, 08:30 we do not have the possibility of recovery of dead modules?
I can read chip but would need a working unit to pull code from I will ask about my friends to see if any one has a unit.
Digimod
Pro
Post by Go4IT »
I've ordered an USBDM for about 12€ from China, and a XPROG for 50€ from Germany. Guess the later one arrives next week, then i can rip the firmware off, hopefully :-)
marekrbk
Active member
Post by marekrbk »
[quote=Stevebe post_id=1591 time=1580924231 user_id=49]
6g9n-18k463-bs
the last number may no NEED * BS *
6g9n-18k463-xx
Post Reply
