but you not think its easier ti look wich can messages will send and on wich can messages it will give reaction...and write your own code....i dont thin thats a big deal...when my cangatway arrives i will try...
ronald0001 wrote: ↑26 Jan 2020, 22:16
Sorry, I completely forgot about it - just because I was stubborn to read the hex dump - I forgot to share the CAN dump - my bad
Can_bus_monitor_MS_.log
Can_bus_monitor_HS_.log
Can_bus_logger_full60sek.log
I did for all HS / MS lines with a time bar. Also during the bench test, I noticed that some Can messages were not coming when the engine was off. - In my test environment, I only have bcm and IPC without ECU. may be the reason I missed the CAN message
LOG's Are to big to post direct on forum
better do a hs-can and ms-can trace while you drive...
deactivte auto pam while driving...
after do a trace ms/hs-can with activated auto pam while drive....
so you can find better the can ids when you compare them
