Gwe89
Pro
Post by Gwe89 »
Ursadon wrote: ↑08 Jan 2020, 15:11
Artist wrote: ↑08 Jan 2020, 14:46 Hi Ursadon, if you're bored, try implementing multiple image changes in the "Help Screen" section of another version of ConversHacker ...
The boys have already come up with the great idea of ​​converting still images into pseudo-animation. It would be nice if the selection was marked with a number and Convershacker was able to replace these images when selecting an image from a computer.
Of course, this can be solved manually, but among other settings you can think ...
Basically, I wanted to thank you for the great work and return to this forum. Thanks to you, you are moving a lot of things that definitely include “Thanks”
The idea is good, unique.
when there is free time, I will try to experiment in this direction, if no one else does it before.
At the moment, we are putting final touches on the new Convers IMG hacker release with DGAlexandru, then I plan to continue develop IPCupdate in order to cover all the modules and create a free analogue of UCDS. Of course, with the help of members of the forum ;)
Have you thought about making the ipc update work with ucds also, just a thought,
Anyway last update of convershacker great tool you guys are very clever people
User avatar
Ursadon
Active member
Post by Ursadon »
New release.
## [1.3.0] - 09-01-2020
### Added
- Wallpaper generation (Main->Create wallpaper)
New wallpaper saved in folder "Converted" in full flash format (.vbf)
logo offset: 0x30120000
Modified mainFW (changed logo offset):
Firmwares/Main-CustomLogo-8M2T-14C026-CE.vbf - **for vFL**
Firmwares/Main-CustomLogo-CS7T-14C026-CD.vbf - **for FL (not fully tested)**
ConversHacker-v1.3.0.zip
peter
Starter
Post by peter »
please check attached vbf. I hope is ok, and can be used on all main vbf
DGAlexandru
Pro
Post by DGAlexandru »
@peter
I don't think you can delete only 4 bytes even in Main Flash.
You need to delete an entire flash page / sector.
Also, not all Main FW versions use the same region in flash to store the offset where the Boot Logo is, so this won't work as expected.
peter
Starter
Post by peter »
ok, attachment deleted
User avatar
Ursadon
Active member
Post by Ursadon »
DGAlexandru wrote: ↑09 Jan 2020, 16:32 @peter
Agreed.
Minimum chunk size for delete - 0xFFFF (Main Flash). So, it’s a little difficult to make an online patcher
tomy75
Active member
Post by tomy75 »
@Ursadon
@DGAlexandru
Can you please make tutorial how setting theme, color pallete,custom BGR file for FL and preFL convers?
Thenx
User avatar
Stevebe
Pro
Post by Stevebe »
Ursadon wrote: ↑09 Jan 2020, 16:53
Agreed.
This is probably me getting it all wrong but Looking through the VBF doc. Z
Can the “ At address”. Be used I know it’s only one byte at one address can the command be used like blocks
This function sets a byte value at a specific address.
On the Edit menu, click At Address. Enter an address, a byte value, and press the OK button.
Digimod
DGAlexandru
Pro
Yes, VBF allows this. Peter approached this way. The problem is that you can't modify a byte in a flash type memory unless you delete it first.. and you can't delete only a byte but a whole page / sector from that flash.
On an EEPROM memory type you can write only a byte.
User avatar
Stevebe
Pro
Post by Stevebe »
DGAlexandru wrote: ↑09 Jan 2020, 17:15 Yes, VBF allows this. Peter approached this way. The problem is that you can't modify a byte in a flash type memory unless you delete it first.. and you can't delete only a byte but a whole page / sector from that flash.
Yeah of course my bad wasn’t thinking of corse it’s flash. I was using the command to change single byte in EEPROM.
Digimod
Post Reply
