Nice !
Hey am i doing something wrong with new version? It don't show my custom logo, old version does tried vbf and bin formatUrsadon wrote: ↑05 Jan 2020, 17:10 New release
## [1.2.0] - 05-01-2020
### Fixed
- Minor UI updates
- Fix show Image at offset - now jumps to image regardless of file.
### Added
- Screenshot via JTAG (JLink) feature
In next release: adding custom wallpaper & generating VBF (both: MainFW & Flash), so you can easy set wallpaper! Stay tuned
ConversHacker-v1.2.0.zip
something is. some files work, others don't. logo in main.
there was a file in the forum WF0EXXGBBEAB68326_black_mondeo_tits.vbf and there is a problem with this file.
Generally a nice program.
Forum search does not find this file.
Can you attach your .vbf file? It seems like decoding issue.
You are using version 1.0.1, and I have 1.1.0 as the base.
Not native English speaker
DGAlexandru
- Pro
@Gwe89 try with CH 1.1.0.. it's still here, at one of my previous messages.
We did some changes from v1.1.0 to v1.2.0 to the function that decodes the image, but should't affect the normal BIN / VBF files. If is still broken, then upload the file you use too see where is the problem.
DGAlexandru
- Pro
Ok, found the problem that was causing the incorrect display of the custom logo present in WF0EXXGBBEAB68326_black_mondeo_tits.vbf file.
We will release a new version with the needed fixes (value declared as int16 instead of int32 and bad offset diff for InFileBGR).
@all
Anytime you find a problem with a new release you should let us know.
This time the problem was that I made a lot of code-optimizations between v1.0.1 to v1.1.0 and forgot to apply all of the code optimization to all the functions.
@all
V1.1.0 loaded as binDGAlexandru wrote: ↑06 Jan 2020, 07:42 @Gwe89 try with CH 1.1.0.. it's still here, at one of my previous messages.
