as you seem to have the right mindset i upgraded you to "Standard user", so you can use all the forum functionality from now on. Please use it with respect of the rules and goals of this forum! But most of all, have fun
IPC edit
Re: IPC edit
Hey phx-
Re: IPC edit
Thank you very much, i will try do my best to be a good member and i will try help with everything and learn everything
never give up !
Re: IPC edit
That WAS spam and the reason why i made this landing zone
yandex.ru
Re: IPC edit
ok - there is one more custom SW with parktronik (and other mods) made by orion512:
https://www.youtube.com/channel/UCpd14H ... OZkOL1SVJQ
Re: IPC edit
i saw that battery voltage, that looks great, never seen it beforemayak wrote: ↑02 Jan 2020, 12:39 ok - there is one more custom SW with parktronik (and other mods) made by orion512:
never give up !
Re: IPC edit
first post and you can't even say hello Marcin. You immediately ask if we will share something. What can you give in return? are you going to share something? skills, knowledge? or just take what you find here ?
Tourist
Re: IPC edit
Do you have proof of this? Links?
If so, sharing itself is no problem at all, if there is a link to this forum - but claiming other ones work to be own is a shame.
Bit on the other hand, the Internet is full of copy-clones, so what. The difference between people who can DO and people who could only COPY is that former ones are always steps ahead
BTW guys: Keep off your dispute from this forum. I know you have your problems, but this is of no interest here. I will delete all that junk anyway...
