Dither and add features separately to Convers+
Artist
Active member
Re: Dither and add features separately to Convers+
Post by Artist »
As far as I know, I changed and added Light Pack only in "Main". The external Flash file has remained unchanged, so it's not mixed in Flash ...
Nothing worked with UCDS, it just didn't work, that was my answer. Nothing has ever been displayed and switched!
The beam light was stable when the parking lights were switched on, and there was no change when the main beam was switched on. Therefore, I ask if anyone has a similar experience! I was not interested in what was written on UCDS, nor was there any response from UCDS support.
I've been driving like that for over a year. So again, I say absolutely nothing!
It's no harm to buy only those features that are in the car. Some features are subject to external hardware. I don't want the DPF indicator when I don't have a hw module ... And so it's similar to some other features.
Please write only real experience, not advertising from the site ...
DGAlexandru
Pro
Post by DGAlexandru »
@Artist
Do you have Low Beam Always On? If yes, then this it why you never saw the difference ;)
I've installed UC DS versions for Convers+ on many cars and it worked in all of them.
Artist
Active member
Post by Artist »
No, just the long beam that is in the picture above
DGAlexandru
Pro
I was referring to the CCC settings of your car. If you have that option enabled then you will have your low beam always turned on as long as you have contact on (ACC on / contact position II).
ronald0001
Active member
Post by ronald0001 »
no i wait for es27 to make a dump for the forum here with installed ligth pack (lower beam, high beam, fog, direction ligth)
i install the mod now with my elm327 on my convers...
i found something strange....when the convers restarts after flashing exe partition the ligth mod works...so the resources all inside of the flash....after first install....
i think that all is enabeld the convers mod file of flash(all mods wich you can get for convers)
only need to flash the exe if you have any mod installed rigth now
only need enable in exe....
i will compare later (if i found my netbook) the old mod files with the new modfiles of conversmod....
also i take a look into the elm fw loader from conversmod....
i found the header of the vbf in that file.....
and its not crypted...so i think maybe can be extractet from the .text (inside of exe)
if it possible to extract the files i dont have to wait for the es27
ronald0001
Active member
Artist
Active member
Post by Artist »
Now it works as it should and without change in Asbuilt data ...
I do not want to repeat and express the same opinion ...
They could add it to the UCDS, even if they didn't talk to Motral anymore ...
In addition, Motral once reminded me that I would not be able to use the light package on my car. We are still talking about the 2006-2010 car and IPC Facelift in the old car ...
I am very satisfied with Convers +.
I don't miss anything. Only a few details are possible, such as turning off the door, even with the rear trunk. But maybe I'll figure it out later ...
ronald0001
Active member
why it should not work with your car?...
mine is a prefacelift 2008...
Artist
Active member
Post by Artist »
Still unnecessary posts !!!
This is not possible with the UCDS package I had and was posted here.
Everything is explained above with a demonstration of what UCDS provides and what should really work in a lightweight package.
You ask why it shouldn't work? But because the data was missing probably because!
As already mentioned, we are talking about a car with Facelift Convers + installed.
Predfacelift I have a complete package with the Webasto indicator for the preFacelift model. The one I didn't have to deal with was completely satisfying for me.
I needed to solve Facelift model !!! Where I personally added color themes and light mode !!!
How should I explain it better ???
In my first post, I posted data that needs to be modified to work. So it's functional and verified on my and other cars. Personally, I do not have to solve anything, I have it solved and it works for me !!!
But without the added blocks in the first post it didn't work.
Logically, they would not be so different and there were no empty spaces in Maine.
So it couldn't go ...
But there are still questions as to why it shouldn't go, and so on, and not after real testing and uploading to the IPC, but only from rumors and rumors ...
Post Reply
