Playing with Lin Bus
User avatar
Stevebe
Post by Stevebe »
Just received Artem’s CANHACKER Units with the Lin Bus option . My first LIN BUS captures
https://en.wikipedia.org/wiki/Local_Int ... ct_Network
Digimod
Re: Playing with Lin Bus
Cool adaptor. Where did you buy it and how much do they charge for it?
User avatar
Stevebe
Post by Stevebe »
Sent you email
Digimod
Pleas tell more about what you are doing above. Just captured LIN of lightswitch in different state?
Can we manage to decode the protocol?
User avatar
Stevebe
Post by Stevebe »
This is a capture of the LIN BUS from the light switch Ford Galaxy, S Max Mondeo, The PC is acting as Master and the switch slave, the capture shows the master polling the switch
Who’s ID 0x11 there are 2 bytes of data 0x20 0x00 side lights on. Then CRC .. the unit also has other address ID’S 0XAD WHICH is a 8 byte data, but I have not had time to dig further , there are a group of ID’S ON LIN BUS V2. THAT HAVE SPECIAL functions. I will post as I go. I’m hopeless at putting words to paper so if any think sounds wrong it probably is.. lol.
This may help make sense of my jabbering
https://www.csselectronics.com/screen/p ... anguage/en
Digimod
