Alarm module pictures
User avatar
Stevebe
Post by Stevebe »
Just a few pictures of theFord Galaxy FL Alarm module will up date with more info when I can
Digimod
Re: Alarm module pictures
Would be nice if you add a "teardown" to my wiki: https://mk4-wiki.denkdose.de/en/artikel ... e/teardown
First, make a picture from front and rear of the PCB. Add frames around parts and add numbers to them.
Next, make a liste of the markings and SMD packages you find. Then try to find the real partnumber from the SMD markings.
Also, i see a TJA1020, so the device is talking CAN. You can try to add 12V to it and scan the CAN for messages. If it does not emitt some on powerup, try to send IGN signal on CAN. Note the CAN IDs it sends, and also log the transmition.
User avatar
Stevebe
Post by Stevebe »
Go4IT wrote: 20 Jul 2019, 20:25 Would be nice if you add a "teardown" to my wiki: https://mk4-wiki.denkdose.de/en/artikel ... e/teardown
will do
Digimod
marekrbk
Post by marekrbk »
my job, replacing the battery and hacking into mondea
