IPC test and data mode
User avatar
Stevebe
Post by Stevebe »
hi all is there any way of reading the NVram version of the convers on the bench, i have it powered up and with ignition Can i can run and program with UCDS but im not certain how get the convers into test/data mode, when its in the motor you hold RHS ok button and ign to 1. Can anyone help
or can the version be read from the EEprom
Since this post and due to some help I have managed to get the convers into test mode video
https://youtu.be/YBIg-FFfog0
Digimod
Re: IPC test and data mode
Looks interesting, how did you manage to get IPC on bench startup without annoying warnings about malfunctions? You showed your CAN-sender shortly in the video and it looks like you are sending much more than simply IGN-ON, right?
And what is those lower screenshot, which looks like UCDS? How to get there? What is it used for?
User avatar
Stevebe
Post by Stevebe »
i used UCDS to show when a menu button was pressed this was before i have a propper menu switch all i used was buttons in a chain and diods as volt drop,
only sent ign on wile hold ok button then just pressed ok to cancel any error displayed
this was a long time ago like you and GW have decided to look into the convers again
Digimod
I never knowed that UCDS is capable of sending buttons, must take a closer look where to find that...
I have attached a button but always end up in a engine malfunction or some errormessage which seem to keep the Convers+ from entering testmode.
