Program navigation target by CAN
Had anyone tried to figure out how the satnavs (FX, NX, MCA) could be set with a navigationtarget via CAN commands?
I know there must be a way to readout the saved targets from the satnav and choose one of them, because that's the way the IPC does. But could it be possible to program a full target in means of an address or GPS coordinates?
oscarboiro
Re: Program navigation target by CAN
Post by oscarboiro »
Hello Go4IT.
I only sniff the can bus signals from V2C to put navigation menu in the screen, in the kuga Mk1 i can't put complete address from voice, i don't know any more about this.
Kuga MK1 owner
User avatar
Stevebe
Post by Stevebe »
I know its on MM can
Digimod
oscarboiro wrote: 26 Dec 2020, 21:28 I only sniff the can bus signals from V2C to put navigation menu in the screen, in the kuga Mk1 i can't put complete address from voice, i don't know any more about this.
I think the only way is to use it with an FX, as the touch-satnavs does it internally and there is no need to put anything on the CAN. I've build a complete test-setup here on my desk and try to investigate further.
