Pats incode outcode calc
Gwe89
Post by Gwe89 »
Hi has any one managed to find a calculator that will do the newer pats system 1144 incodes 2010 onwards
Re: Pats incode outcode calc
Which cars uses this? I thought i've read that cars from 2011 onwards use newer algo?
Gwe89
Post by Gwe89 »
Yes from 2011 its new algorithm
UCDS lacks on this also. I even cannot start ABS bleeding, which ForScan can. I made bug reports on this but they don't care.
Syntax
Post by Syntax »
Does anyone have any new regarding the incode calculator for 1144 outcodes?
I need to sync PCM with PATS but I don't have the correct calculator :(
Gwe89
Post by Gwe89 »
I have found a contact that can program newer pats with FRDS, he did it remotely with my ucds, my vcx nano would have worked also, programmed my new bcm and keys and added a 3rd key
I guess only chance right now is to use IDS, resp. FJDS which is a subset of IDS. But for this you need to buy a licence and also got a compatible adapter.
Gwe89
Post by Gwe89 »
Go4IT wrote: 16 Jul 2021, 19:03 I guess only chance right now is to use IDS, resp. FJDS which is a subset of IDS. But for this you need to buy a licence and also got a compatible adapter.
Genuine ucds works with FJDS
Gwe89 wrote: 16 Jul 2021, 20:08 Genuine ucds works with FJDS
Great, but FJDS needs a license, so i can't really test. Also Licenses are not sold to EU citizens, because official Ford shop only accepts US creditcards :-( So how can i get one?
And, do FJDS needs an ETIS login also, like IDS?
DGAlexandru
Post by DGAlexandru »
Acess to Ford online PATS needs a Ford or authorised dealer account.
For Europe, in order to be able to have access to PATS as an authorised dealer you have to undertake some checks from a specialised 3rd party. This process costs 500€ and is available for 1 or 2 years. If there is something wrong with the papers you provide they reject you and then you have to pay another 500€ to start the process all over.
If you have a J2543 OBD interface and Euro5 car I might have a solution for you by using a USB passtrough over Internet solution :roll: (J2543 interface connected to car and a PC, USB passtrough software, Internet, USB passtrough software, my PC with FDRS)
