Page 1 of 1
				Hcm issue afs headlights
				Posted: 20 Sep 2020, 15:15
				by amplified
				I did ucds update to hcm and now front light malfunction stays permanent.
What i tried but no luck:
Make headlight calibration both with ucds and forscan
Downgrade to previous version and repeat calibration.
 Nothing helps.
I got u3000 and b11f1
				Re: Hcm issue afs headlights
				Posted: 20 Sep 2020, 19:56
				by DGAlexandru
				Going back to the previous calibration version should have fixed this issue or at least let you calibrate the headlights.
Put a screen capture also for the original calibration - from uuw file that was automatically saved in UCDS's "Session" folder.
Try to write the same files using VBF Loader but by writing them in other order (SBL stays first, but after it put first ECU Calib. Signal then ECU Software / Exec.)
				Posted: 22 Sep 2020, 13:48
				by amplified
				I tried uploading in different order (the original calibration before update)
I tried upload one at a time...
no change.
Will there be any difference if i try different headlights?
				Posted: 24 Sep 2020, 01:37
				by Stevebe
				amplified wrote: โ22 Sep 2020, 13:48
no change.
Did you try reset
				Posted: 24 Sep 2020, 04:28
				by amplified
				Many times.
What I havenโt tried is to program it as dead module.
I will try that and if not help i would find ford ids to try program or calibrate.
				Posted: 24 Sep 2020, 08:06
				by tomy75
				Hello
try cleaning the connectors on the headlight
				Posted: 17 Nov 2020, 18:13
				by amplified
				All fixed!
Thanks Tomy, after i cleaned then once i tried with different cleaner and more cleaning and it worked.
				Posted: 17 Nov 2020, 22:36
				by tomy75
				Posted: 11 Dec 2020, 17:45
				by Go4IT
				WOW!
