Ford Incode calculator for program Keys
All software topics
oscarboiro
Post by oscarboiro »
Hello,
To program keys need calculate a Outcode, i have acces to Ford Etis and i can calculate it, but the Etis need write some infomration: Vin, part number etc etc... and validate on the server..... very slow to program keys on a old cars, the new system is automatic and only need validate on etis.
Last times i use www.autokeyprog.com. To calculate the Incode only need write the Outcode, but now this page are offline and dont work.
I install software of TM100 Key programmer, this software have a Incode calculator withouth limitation, but is very slow to start, need run on administrator mode and try to cennect to adaptor, but idont have this adaptor and show some fails, after some time strats and i can use.
my question is, is possible calculate algorithm of pats to made my own Incode calculator? i have a file on txt with a lot of Outcode - Incode numbers but i cant found any logic.
Kuga MK1 owner
DGAlexandru
Re: Ford Incode calculator for program Keys
Post by DGAlexandru »
Hi,
I also have over 200 single pats and over 120 double pats outcode / incode pairs.
Maybe we should share them and see if we can get to a conclusion.
oscarboiro
DGAlexandru wrote: ↑30 Aug 2020, 22:45 Hi,
The double pats is this, 2 outcode, one from the instrument cluster or kvm and another from pcm, normally with same algorithm, i study on my kuga mk1 with keyfree ans siemens PCM, and the algo is the same to pcm and kvm, but in the last kuga mk1 with delphi dcm3.5 have different algo to pcm.
example of double codes:
Kuga mk1 with siemens PCM: 0044 DCAFEA F00CB7
Kuga mk1 with delphi PCM: 0042 DCAFEA F00CB7
i try some outcode calculators and any calculate the 0042 outcode correct and i only can program with ford IDS.
from sigle codes 0040 i only found one logic in last digit from 4 consecutive numbers:
incode-------------outcode
000001------------F680
000002------------F681
000003------------F682
000004------------F683
000005------------FF64
000006------------FF65
000007------------FF66
000008------------FF67
000009------------0745
00000A------------0746
00000B------------0747
00000C------------0748
00000D------------0759
00000E------------075A
00000F------------075B
000010------------075C
000011------------1791
000011------------1792
000011------------1793
000011------------1794
I can sniff can bus when i program keys with IDS in new modes to take incodes and outcodes with new algorithm, but this is interesting to use old version of ids with old procedure. now etis cant generate 0042 codes manually.
Kuga MK1 owner
The generation of these codes are only necessary to gain "PATS Security Access" in case you change something in PATS. This means to me, it is just another obstacle until the PATS system (which is realized in software inside the BCM) is willing to accept any change, see it like a "password". The algorithm of calculating an INCODE from an OUTCODE (which is like the "challenge" from the PATS system) is unknown to us, so we are not able to verify them or generate them.
I'm not convinced that an OUTCODE necessarily contains the part or make of a model, but could if the algo uses those data for entropy. But also does not matter, as regardless of the code, you can't simply bruteforce it (8 Bytes) and only one answer is correct.
On keyless-systems this also works with these codes, but the operator is not able to enter them manually, they are fetched from Ford online, directly via the tester. But on the CAN and PATS-level, everything stays the same.
