Analyze filesystem found in Flash
Hi, i think i found a filesystem inside the Flash of the FX (NX and MCA should have this also, but for now i look on FX).
When i browse through the content of the dump i find this:
Code: Select all
01681400  49 4E 4F 44 01 00 00 00 68 05 00 00 00 00 00 00  INOD....h.......
repeating every 0x200 (which equals a blocksize of 512 Bytes) up to
Code: Select all
01EB8600  49 4E 4F 44 05 00 00 00 00 00 00 00 00 00 00 00  INOD............
There are also some other node-types having "MAST", "INDI" and "INDX" as type identifier. For me this looks very of a filesystem. As we already now, the software running on the OMAP5948 is Nucleus RTOS, developed by Siemens (https://en.wikipedia.org/wiki/Nucleus_RTOS).
This could be run without an FS, but there are serveral drivers, even special ones for flash chips (the S29GL of FX is a NOR-Flash). Datalight INC. has an RTOS which also provides such driver, named "Reliance Edge". Here are the sources on Github and i point right to a header-file where we found the refs for the above strings:
https://github.com/datalightinc/relianc ... ped_q=INOD
Code: Select all
#define META_SIG_MASTER     (0x5453414DU)   /* 'MAST' */
#define META_SIG_METAROOT   (0x4154454DU)   /* 'META' */
#define META_SIG_IMAP       (0x50414D49U)   /* 'IMAP' */
#define META_SIG_INODE      (0x444F4E49U)   /* 'INOD' */
#define META_SIG_DINDIR     (0x494C4244U)   /* 'DBLI' */
#define META_SIG_INDIR      (0x49444E49U)   /* 'INDI' */
I try to reverse engineer the FS, maybe there are some good forensic tools for this. Right now i try to understand "by hand" how it's made. My goal is to build a tool to "read" the filesystem and then maybe also write it.
The reason why we find the inodes only on the upper half of the flash may be that the lower part is used to boot the kernel and the needed FS for storing data read from SD/CD/DVD or just temporary and persistent files must be stored somewhere.
Re: Analyze filesystem found in Flash
I found an interesting introduction into Flash filesystems here: https://www.ibm.com/developerworks/linu ... lesystems/
We find many occurences like this
Code: Select all
/dev/ffs/FC_DOWNLOAD_VER.DAT
where "FFS" stands for "Flash-File-System") or {RFFS_s32Format} Formatting drive %c: {RFFS_s32Format} where "RFFS" indicated "Reliable Flash File System".
I recently installed binwalk on one of my Linux boxes (running headless Ubuntu 16LTS) and see what this find in the whole dump. Quite interesting:
Code: Select all
root@ubuntu16:~$ binwalk fx_flashdump.bin
DECIMAL       HEXADECIMAL     DESCRIPTION
1310752       0x140020        ELF, 32-bit LSB executable, ARM, version 1 (SYSV)
1311328       0x140260        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
1351872       0x14A0C0        Unix path: /dev/registry/LOCAL_MACHINE
1370352       0x14E8F0        Unix path: /dev/ffd/CD_PARAM
1394524       0x15475C        Unix path: /dev/ffs/FC_DOWNLOAD_VER.DAT
1400528       0x155ED0        Unix path: /dev/ffd/CD_PARAM
1405992       0x157428        Unix path: /dev/fgs/dim
1437636       0x15EFC4        Unix path: /dev/adc/7
1441568       0x15FF20        Unix path: /dev/ffs2/FC_SPM_ENG.dat
1443820       0x1607EC        Unix path: /dev/card/em_trace.bin
1448356       0x1619A4        Unix path: /dev/ffd/TTFIS
1517876       0x172934        Unix path: /dev/ffs/mif/mif01.cfg
1519156       0x172E34        Unix path: /dev/ffs/mif
1520320       0x1732C0        Unix path: /dev/ffs/CRDSHARE.DAT
1634480       0x18F0B0        Copyright string: "Copyright (c) 2003 - 2005 Datalight, Inc."
2095836       0x1FFADC        Copyright string: "Copyright (c) 2003 - 2005 Datalight, Inc."
2387584       0x246E80        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/BASE/DOWNLOAD/CHINASIBD
2418955       0x24E90B        Copyright string: "Copyright MGC 2003 - Nucleus PLUS v. 1.14.5 - ARM926T TI OMAP5912 RVCT 2.0.1"
2427712       0x250B40        CRC32 polynomial table, little endian
2444640       0x254D60        Unix path: /dev/adc/0
2481652       0x25DDF4        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT
2490324       0x25FFD4        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
2507828       0x264434        Unix path: /dev/ffs/FC_DOWNLOAD_LMM.DAT
2508672       0x264780        Unix path: /dev/registry/LOCAL_MACHINE
2509996       0x264CAC        Unix path: /dev/ffs/FC_DOWNLOAD_FEA.DAT
2513944       0x265C18        Unix path: /dev/registry/LOCAL_MACHINE
2515404       0x2661CC        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/NAVAPP
2520176       0x267470        Unix path: /dev/ffs/cfg/navdreg.reg
2524604       0x2685BC        Unix path: /dev/ffs/FC_DOWNLOAD_CRC.DAT
2526836       0x268E74        Unix path: /dev/ffs/DnlSrcUSB.set
2528768       0x269600        Unix path: /dev/registry/LOCAL_MACHINE
2537168       0x26B6D0        Unix path: /dev/ffs/DSDSE.CFG
2541572       0x26C804        Unix path: /dev/ffs/download.off
2543580       0x26CFDC        Unix path: /dev/ffs/ffsbat.ena
2547964       0x26E0FC        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
2565196       0x27244C        Unix path: /dev/registry/LOCAL_MACHINE
2568072       0x272F88        Unix path: /dev/ffs/chinasi.cfg
2571508       0x273CF4        Unix path: /dev/ffs/DnlSrcUSB.set
2574892       0x274A2C        Unix path: /dev/fgs/download
2579000       0x275A38        Unix path: /dev/rp_if/download
2605532       0x27C1DC        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS
2610976       0x27D720        Unix path: /dev/ffs2/FC_SPM_LMM.dat
2640488       0x284A68        Unix path: /dev/ffs2/FC_SPM_ENG.dat
2651532       0x28758C        Unix path: /dev/ffs2/FC_SPM_LMM.dat
2661392       0x289C10        Unix path: /dev/rp_if/power
2662772       0x28A174        Unix path: /dev/registry/LOCAL_MACHINE
2677180       0x28D9BC        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/NAVAPP
2678540       0x28DF0C        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/SDS
2683752       0x28F368        Unix path: /dev/ffs2/base.reg
2685612       0x28FAAC        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/SYSTEM
2686832       0x28FF70        Unix path: /dev/ffs2/FC_SPM_LMM.dat
2689460       0x2909B4        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/BASE
2691804       0x2912DC        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
2694004       0x291B74        Unix path: /dev/fgs/system
2724700       0x29935C        Unix path: /dev/ffs/Bluetoothtest.bin
2725584       0x2996D0        Unix path: /dev/ffs/dabtest.bin
2726844       0x299BBC        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS/
2728156       0x29A0DC        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/NAVAPP/
2728928       0x29A3E0        Unix path: /dev/ffs/FC_DOWNLOAD_VER.DAT
2737984       0x29C740        Unix path: /dev/registry/LOCAL_MACHINE
2768532       0x2A3E94        Unix path: /dev/registry/LOCAL_MACHINE
2789948       0x2A923C        Unix path: /dev/registry/LOCAL_MACHINE/software/blaupunkt/process/navapp/data_server/app_config
2792032       0x2A9A60        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/BASE/SPM/APP_THREAD
2798496       0x2AB3A0        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS/BASE_SW_VERSION
2799952       0x2AB950        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/BASE/SPM/APP_THREAD
2800116       0x2AB9F4        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/PROCESS/BASE/SPM/AIF_CONFIG
3027871       0x2E339F        Copyright string: "Copyright (c) 1993-2005 Datalight, Inc."
5503142       0x53F8A6        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
5768812       0x58066C        Unix path: /dev/cryptcard/RT2/RT3.TXT'
6207992       0x5EB9F8        Unix path: /dev/ffs2/burnin
6260754       0x5F8812        Unix path: /dev/ffs/FC_AUDIOPL_LMM.DAT
6418819       0x61F183        Unix path: /dev/ffs/VD_DIMMING_LMM.DAT
6680854       0x65F116        Unix path: /dev/ffs/UAM_LMM.DAT
6735014       0x66C4A6        Unix path: /dev/ffs2/bHA
7562448       0x7364D0        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
8124681       0x7BF909        Unix path: /dev/ffs/PDATA_MNGR_LM.DAT
8277662       0x7E4E9E        Unix path: /dev/registry/LOC#`w
8505172       0x81C754        Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
8641485       0x83DBCD        Base64 standard index table
9660287       0x93677F        Unix path: /dev/ffs/rcerr_%03d.log
12836002      0xC3DCA2        Unix path: /dev/ramdisk/fcsina2L
13107224      0xC80018        Unix path: /bin/nucleus/arion/release/ -IY:/build/nucleus_core/init/nucleus/arion/startup_r/release/ -IY:/build/nucleus_core/init/nucleus/a
16906438      0x101F8C6       Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
17172108      0x106068C       Unix path: /dev/cryptcard/RT2/RT3.TXT'
17611288      0x10CBA18       Unix path: /dev/ffs2/burnin
17664050      0x10D8832       Unix path: /dev/ffs/FC_AUDIOPL_LMM.DAT
17822115      0x10FF1A3       Unix path: /dev/ffs/VD_DIMMING_LMM.DAT
18084150      0x113F136       Unix path: /dev/ffs/UAM_LMM.DAT
18138310      0x114C4C6       Unix path: /dev/ffs2/bHA
18965744      0x12164F0       Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
19527977      0x129F929       Unix path: /dev/ffs/PDATA_MNGR_LM.DAT
19680958      0x12C4EBE       Unix path: /dev/registry/LOC#`w
19908468      0x12FC774       Unix path: /dev/registry/LOCAL_MACHINE/SOFTWARE/BLAUPUNKT/VERSIONS
20044781      0x131DBED       Base64 standard index table
23611146      0x168470A       Unix path: /dev/acousticout/speech/0
24419594      0x1749D0A       Unix path: /dev/acousticout/speech/0
24703242      0x178F10A       Unix path: /dev/acousticout/speech/0
25321738      0x182610A       Unix path: /dev/acousticout/speech/0
25753354      0x188F70A       Unix path: /dev/acousticout/speech/0
25829130      0x18A1F0A       Unix path: /dev/acousticout/speech/0
26294538      0x191390A       Unix path: /dev/acousticout/speech/0
26782986      0x198AD0A       Unix path: /dev/acousticout/speech/0
28001546      0x1AB450A       Unix path: /dev/acousticout/speech/0
29254410      0x1BE630A       Unix path: /dev/acousticout/speech/0
29594378      0x1C3930A       Unix path: /dev/acousticout/speech/0
29674494      0x1C4CBFE       MySQL ISAM index file Version 1
32208138      0x1EB750A       Unix path: /dev/acousticout/speech/0
latigido
Post by latigido »
Hello,
As you see at bin offset 0x140020 there is an ELF, 32-bit LSB executable, ARM.
So extract this 140020.elf and load to IDA as elf and use ARM Little endian.
After, you can see in example this code(note:elf partition is extracted from 8S7T-18K931-AD_7612300524_PIN-8367.bin):
Code: Select all
SDRAM_RO:900A35D0                 BL      sub_900A3242    ; SDcard_Signature_check
SDRAM_RO:900A35D4                 CMP     R0, #0
SDRAM_RO:900A35D6                 BNE     loc_900A35EE
SDRAM_RO:900A35D8                 ADR     R0, aSignatureFileS ; "Signature file successfully verified"
...so here you can simply patch branch "BNE loc_900A35EE" to "NOP".
(using some hex editor, change two bytes at 0x900A35D6: 0A D1 to C0 46 - this is opcode of NOP in Little endian)
Ok, please let me recap this: How to extract the ELF? using "binwalk -d 'elf' dump.bin" oder just by removing everything prior to 0x140020 from the hexfile, yes?
Next, load this into IDA Pro, it will default ask for ARM Thumb little endian, which looks good for me.
1.) IDA then scans through whole image, determines a lot of subs and segments. Could you tell more about it?
IDLE_ENTRY
POWER_MODE
SDRAM_INIT
SDRAM_RO
DOE_SDRAM_RO
TESTCODE_RO
where did the descritpors come from? The developers?
2.) The "start" seems to be the entrypoint of the software at 0x9000 0000 (so this is a relative offset in the address-range of the OMAP right?)
3.) SDRAM_RO:90000178 ADR R2, aStartFordHsrns ; "** Start FORD HSRNS System "
Sound pretty cool. So there may be some debug output facility somewhere, right? How to get where this is going to? Maybe a serial output...
Oh, i've got sooo many questions! Find this all exciting, want to learn more from you! :-)
latigido wrote: 25 Jul 2020, 08:18 ...so here you can simply patch branch "BNE loc_900A35EE" to "NOP".
Mate, you are so genius! Could it be that easy?! ;-) Let's find this damned PIN algo...
latigido
Post by latigido »
ok, I will search for It.
DGAlexandru
Post by DGAlexandru »
We allready have this patch for NX SD version (NX NCA) available on Internet for at least 3 years... but finding more things like this maybe will let us get more from these audio units.
Great job!
With binwalk we again learn a lot about the internals of the firmware and how it is made. An ELF is something like an executeable image (correct me if i'm wrong!). It contains some regions (segments) and tells the OS which loads and executes it where to put it in memory, what to call to start it up and which parts of the image could be only read, read/write and executed. It also could contain static bound (included) libraries.
In the above case the target-location of the image (0x9000 0000) points into the external SD-RAM (EMIFF) area of the OMAP-System, which starts at 0x8000 0000 in our configuration of the FX (see Memory Map). So it means that the ELF will be transferred into SDRAM an get's executed there.
So for me, the ELF is the main software running on top of the operating system (RTOS). I wonder how it get's loaded and executed? This must be part of some boot-process. Also i wonder if the ELF itself is used as part of an filesystem or if the bootloader knows it by address location in Flash? As RTOS does not need an Filesystem, but we know it has support for it, it could be both ways.
So what do we have right now?
a) 0x0000 0000: The boot/reset vector table
b) The secondary bootloader code (called by the primary bootloader, sit in ROM of OMAP chip)
c) An RTOS kernel image in Flash
d) An ELF application image in Flash
e) Some stack in RAM
f) Some variable data area in RAM
g) A filesystem of some kind in Flash
h) A memory-mapped IO region to address external and internal perihpals
Let's see if we get this together in a big picture.
