Hello
Newly activated users can post here
Teroxis
Hello
Post by Teroxis »
Hello guys,
I'm a 23 Czech guy working as a programmer.
Currently, I am most interested in canbus hacking and MCA (plus) capabilities.
I am currently working on a video switcher for MCA.
Re: Hello
Welcome Teroxis and thanks for introduction!
I'm also highly interested in the navigation systems, and also had build a switcher. Maybe we can work on this together? The main challenge is to enable the video on demand. Therefore i would like to have a separate CAN ID and also a input logic level signal on some unused port.
For this to work, i think we need to disassemble the firmware and find out where the CAN handling routines reside and what needs to be done in firmware to show up the video in.
Also, to react on users choices, there should be a way to read the touch screen and buttons in this mode.
I will now elevate your access rights to other forums of this board.
Vlada871
Re: Hello
Post by Vlada871 »
amplified
Re: Hello
Post by amplified »
what are you showing us here? Video input with screenmirror to simulate android on MCA? :)
Vlada871
Re: Hello
Post by Vlada871 »
No.... android control by touchscreen from mca.
https://youtu.be/KURisV6j8Fw
Re: Hello
Those videos are of no use. No further informations, no proof. Just forget about them and get back to real life ;-)
amplified
Re: Hello
Post by amplified »
@Vlada871 are you the author of the video? If' so please explain it becaue it is all over the internet and no information whatsoever, as Go4IT says... maybe best to just forget them ... i wrote multiple times to the author on youtube without responce.
DGAlexandru
Re: Hello
Post by DGAlexandru »
It can be simply as reading on CAN the status on NX and if in Video Mode then disconnect the touchscreen from NX and send the info to another device which is connected to that Android.
Teroxis
Re: Hello
Post by Teroxis »
I have an identical idea as DGAlexandru...
Use the MCA touch panel to operate with Android device (Raspberry Pi).
The screen uses 4 wire connector, which can be operated used with something like this: https://www.cartft.com/catalog/il/1681
Then You need a "switcher" to switch between MCU and Raspberry to use that panel.
