Android
Android
I have an android radio in my car,I wanted additional features. To work properly I bought a newer can module.  displaying climate information after the can change. I wanted him root with Malaysia rom and works.When it became root ,i used viper audio apk,the sound has improved. i changed my mind about mcu update. https://xtrons.ibus-app.de/index.php?ti ... _Sound-Mod ,parking sensors added after update. using this app MTCAmpRootMod.apk v1.1 the equalizer setting has changed. After these adjustments, the radio is the best travel companion
adding photos
						adding photos
Re: Android
Foto add https://youtu.be/5HrRoiHyv9w
						Re: Android
What model is your radio?
						Re: Android
Can you send link to canbus decoder box, thanks
						Re: Android
unidentified manufacturer, seller from Slovakia
and my canbus
https://www.aliexpress.com/i/32920587074.html
						and my canbus
Re: Android
That is the link you bought it from, right? cause in the link it has a bit different numbers spelled on the label, only sw version the same - is this the only important thing in those boxes? thanks
						Re: Android
Nice, the parking senzors are visible on your navi. You need just that apk or there is something else?
I wonder if there is a solution to see more car info on this units (I have eonon unit) without bt adapter....
Re: Android
I have on bench one android unit now and try to add reverse camera. Video in work fine, but reverse cam not show when I power on it.
This is plug for reverse camera. Do I need to add reverse gear power to show video?
Can you show me your manul, because this unit doesent have...
				DGAlexandru
 - Pro
Re: Android
I think F1 is "Back" detect instead of "Break" detect...
Camera +12V power is from F2, video signal from camera is F8 and a GND - F7 and/or F9.
Re: Android
Video signal I thinkn is F8 + GND. But F1 is 0v, F2 is 0.2-0.3v.. not enaught to power camera
