8M5T-19C112 Language
Did anyone find a way to flash sprm with another language?
Direct vbf upload or somethin?
I have Italy speech module and try to flash it with A...
Re: 8M5T-14D511 Language
I think your topic-title is a bit misleading. Your module is a Bluetooth-Module and the "well known" partnumber of it is 8M5T-19C112. You want to change this...
- Pro
Re: 8M5T-19C112 Language
It should also be in a different section, as this module is not BlauPunkt / Bosch
I played with language swap for this modules, first by modifying the VBF file - Eng language to look like the current loaded language but with no success - it fails at loading the FW.
Also writing / swapping all 3 flash memory chips doesn't change the Part Number of the module, even if the language swap is a success, at a future update from USB it will load the original language files.
That was I think to do.. swap/reprogram eeprom inside.. but when you do this without success.. I think we need to find a way to do this language change
I think we need to disassemble the FW to get know how it work.
The Firmware resides in 3 Flash Chips (2, 7, 5) and an EEPROM (23)
https://mk4-wiki.denkdose.de/artikel/au ... innenleben
Also, if you can read (translate) German, you may want to read my findings here: https://www.mikrocontroller.net/topic/475276
DGAlexandru: did you resolder the Flash chips? Or did you find a way to JTAG/BDM it?
- Pro
Desolder, put in TSOP48 adapter, read and write, then solder back.
The chip that contains language is TSOP56... very hard to find & expensive.. so for this one I did a swap from a broken module.
I never played with that 25C64 EEPROM.. if here is the "language setting" I'm going to kill myself
DGAlexandru if you have pcb on your desk, check this eeprom.. Or I can remove my from car and read and post dump here....
Go4IT just downlaod your dumps and check it.. There is a strange data inside 95640:
WF0GXXGBBGBM18977
8M5T-14D511-BT
8M5T-14D512-AA
8M5T-14D509-AS
8M5T-19C112-BT
8M5T-19C112-BT
A here mean English, B - German... And why VIN is inside this dump
WF0GXXGBBGBM18977
8M5T-14D511-BT
8M5T-14D512-AA
8M5T-14D509-AS
8M5T-19C112-BT
8M5T-19C112-BT
- Pro
@sanndo
read your EEPROM and put dump here.
If you have:
8M5T-14D511-E*
8M5T-14D512-AA - this is common on all languages
8M5T-14D509-AS - this is common on all languages
8M5T-19C112-E*
8M5T-19C112-E*
Then modify them to be "-AN"
Put EEPROM back and read with ELMconfig the info from module.
If something now is with AN then try the update with 8M5T-14D511-AT.vbf file only on USB.
I don't have my soldering station at home.. I had to play with it at a client and I've left it in my car
If you have:
8M5T-14D511-E*
8M5T-19C112-E*
8M5T-19C112-E*
