PBL - functions
Disassemble Convers+ firmware 7M2T-14C026-AG using IDA Pro
User avatar
Ursadon
PBL - functions
Post by Ursadon »
All that you wanted to ask, but were afraid. Answers await you in this thread. :D
I managed to disassemble most of the PBL. Compared to the main RTOS code, it is relatively simple
PBL can be divided into two parts:
1. Initialization of the Periphery
2. The main loop
1. Init
After starting, the processor executes the command at address 0x00000000
In general, at the beginning of the address space is an interrupt table, and at address 0 there is a reset vector
After reset, initiate stack:
Code: Select all
PBL:00001018 LDR     R0, =STACK_BOTTOM_4000BEFC      ; Load from Memory
PBL:0000101C MSR     CPSR_c, #0xD2                   ; mode = IRQ
PBL:00001020 SUB     SP, R0, #0x100                  ; Rd = Op1 - Op2
PBL:00001024 MSR     CPSR_c, #0x5F ; '_'             ; mode = SYS
PBL:00001028 B       loc_3DBC
and after some (mostly) useless function we arrived to PBL_phase1 (0x0000123A):
Line 28 is the configuration of the EIM (configure_PIM_for_EIM() - 0x0000332C). Mapping memory regions:
0x2000000 videoram
0x3000000 external flash
0x6000000 is not mapped - uses the native functions.
Also PBL check "magic number" - "0x7C, 0xC7, 0x55, 0xAA, 0xAA, 0x55" at the beginning and at the end of main flash(0x5000 & 0xFFFF8)
@function j_PBL_check_mainflash_sig
If the test fails, PBL proceeds to the second stage - the so-called “boot loop”. This is when the hazard light is blinking, otherwise control passed to RTOS (0x00005304)
2. PBL main loop
PBL_main_loop() - 0x00001110
The main thread is the "while (1)" loop, where the CAN bus is constantly polled (interval - 1 ms). There are no interrups - only hardcore, only polling
Read CAN bus errors -> update TIF2 -> [if magic_key is ok, then exit from PBL] -> read CAN data
2.1 Reading CAN bus
PBL_CAN_routine() - 0x0000240E
Possible UDS commands:
  • PBL_UDS_DiagnosticSessionControl (0x10) [@0x000019A2] - is used to enable different diagnostic sessions
    Possible values:
    • 0x1 - defaultSession
    • 0x2 - programmingSession
    extendedDiagnosticSession (0x3) is not supported
  • PBL_UDS_ECUReset (0x11) [@0x000018FC]- The ECUReset service is used by the client to request a server reset. Нurn off the watchdog and die in an infinite "while (1) {}" loop
  • PBL_UDS_ReadDataByIdentifier (0x22) [@0x00001A70]
    Possible subFunctions:
    • 0xD100 - current security status (2 - security access granted, 1 - security access not granted)
    • 0xF101 & 0xF102 - not implemented, returns requestOutOfRange error code
    • 0xF162 - returns 0xF162 :D
    • 0xF180 - Software version string (bootloader version)
    • 0xF18C - Serial number - from eeprom @0x7A8 (0x10 bytes)
    • 0xF191 - Part number - from eeprom @0x7B8 (0x18 bytes)
  • PBL_UDS_TesterPresent (0x3E) [@0x00002372] - This service is used to indicate to a server (or servers) that a client is still connected to the vehicle and that certain diagnostic services and/or communications that have been previously activated are to remain active.
  • PBL_UDS_RequestDownload (0x34) [@0x00001E28] - The requestDownload service is used by the client to initiate a data transfer from the client to the server (download).
  • PBL_UDS_RequestUpload (0x35) [@0x00001F92] - The RequestUpload service is used by the client to initiate a data transfer from the server to the client (upload).
    This is where the magic begins with the secondary bootloader (SBL). In PBL mode, there is a memory area reserved for the SBL: 0x40000D70 - 0x40001570 (800 bytes). The first call to this function always places the loaded data in this area. Therefore, the address of the SBL function call is not 0x00000000 (like in .vbf), but 0x40000D70
    All subsequent read / write requests are pre-checked for compliance with the memory blocks (start - end- function_id to deal with it (read/write)):
  • PBL_UDS_TransferData (0x36) [@0x000022E0] - The TransferData service is used by the client to transfer data either from the client to the server (download)
    or from the server to the client (upload).
  • PBL_UDS_RequestTransferExit (0x37) [@0x000022EC] - This service is used by the client to terminate a data transfer between client and server (upload or download).
  • PBL_UDS_SecurityAccess (0x27) [@0x00001B14] - The purpose of this service is to provide a means to access data and/or diagnostic services which have restricted access for security, emissions or safety reasons.
    There is no bruteforce detection. Key generation algorithm - Galois LFSR with modified multiplicator. Secret key is {0x08, 0x30, 0x61, 0x55, 0xAA}.
    I want to focus on an interesting random value generation algorithm - since the MAC7116 does not have a hardware generator, the CAN channel timer value is used as an entropy source (PBL_generate_securitySeed(), 0x00003184):
    If the generated seed does not meet expectations, a predefined value is used - {0x1D, 0x65, 0x65}
  • PBL_UDS_RoutineControl (0x31) [@0x00001CBC] - The RoutineControl service is used by the client to start a routine,stop a routine, and request routine results.
    Possible routineID:
    • 0x301 - call to SBL functions
    • 0xFF00 - erase memory
    • 0xFF01 - check memory (try to read)
Facts
  • None of the PBL functions are used in the RTOS
  • RTOS in not OSEK-compatible (unlike Volvo's V50 IPC).
  • @Go4IT- I don’t know how you broke your IPC 2 years ago - FLASHPROT is disabled during PBL
TODO
SBL detailed functionality clarification
P.S. I don't share sources, I share knowledge
Not native English speaker :cry:
User avatar
Ursadon
Re: MK4 PBL - functionality
Post by Ursadon »
reserved
Re: MK4 PBL - functions
Great job!!! I eager to read and understand your findings, thanks for the work!
tomy75
Post by tomy75 »
I look forward to continuing ;)
User avatar
Stevebe
Post by Stevebe »
Wow that was enlightening
Digimod
oscarboiro
Post by oscarboiro »
Is very interesting, have answers to some questions of my proyect.
thanks!!!
Kuga MK1 owner
User avatar
Stevebe
Re: [MK4] PBL - functions
Post by Stevebe »
Shame this thread died out were is Ursadon
Digimod
amplified
Re: PBL - functions
Post by amplified »
I see in this post that 03 is xtended diagnostic is not supported, is it true or we just don’t know the security key?
