Page 1 of 1
Data on The ms-can
Posted: 28 Jan 2020, 18:00
by ronald0001
Data on The ms-can
#ID // D0, D1, D2, D3, D4, D5, D6, D7,
#200 // D6 (vaule 83,85,86,87,88) shows in convers lamp/light errors
#078 // d5+d6 is rpm ...is dricetly from HEX to DEZ...03 E8 =1000
D7 must be also active (mine is 3c or 3e) otherwhise rpm have no effect to ipc, must look what is d7 exactly
#06b // D7 shows blinker/hazard ligth in c+
D6 when its Zero Gong like Door open starts in the convers (must compare in car if is this funktion)
#048 // D2 break status
D4 ignition status
#040 // D0 position of ligth switch
if someone can give me id´s and the function of this i can alsways edit this topic
Re: Data on The ms-can
Posted: 17 Feb 2020, 09:41
by ronald0001
#260 d7 is water temp hex to dez - 60 than you habe temp.
#84 d1+d2 is speed hex to dex /96 is kmh
Posted: 21 Feb 2020, 07:04
by Go4IT
ronald0001 wrote: 17 Feb 2020, 09:41 #48 d1+d2 is speed hex to dex /96 is kmh
Are you shure? I guess this is a typo and it should be "0x84" instead of "0x48".
Posted: 22 Feb 2020, 16:55
by ronald0001
yes you are rigth...sorry my nisstake
