CCC data Eeprom and BCM
User avatar
Stevebe
Post by Stevebe »
there as a lot of good data in the Ipc Eeprom From CCC to Menü control
Also BCM backs ccc data to eeprom. So started a thread will add to and build as we go
EEprom data
FACE LIFT CONVERS EEPROM
THESE ARENTHE EEPROM MENU FLAGS
16B 03 TPMS Menü
16A 03 LANE DEPART Menu
15B 03 PARK HEATER Menü
165 03 Hill Launch Menu
167 03 Autobeam Menu
the corresponding Main has to be installed
NVRAM INFO @ address
110
111
preface language @ address
544 00 is EN
544 08 is Polish
Digimod
Gwe89
Re: CCC data Eeprom and BCM
Post by Gwe89 »
Found in direct config on ucds under bcm, if you change this to 0 any open windows will go up when you single press the lock button
If have, more or less completely decoded all bytes from CCC config record: https://mk4-wiki.denkdose.de/artikel/fa ... nfig_block
DGAlexandru
Post by DGAlexandru »
There are at least 3 / 4 tools, besides Ford IDS, that we can use for this... Why do we need to reinvent the wheel here :| :roll:
