Nx patch
Gwe89
Nx patch
Post by Gwe89 »
Removes write protection and gives dark theme
bigi
Starter
Re: Nx patch
Post by bigi »
Only problem with this is the maps are a shitty shade of brown when using dark mode I discovered :lol:
Re: Nx patch
Right, this looks terrible. Somebody of us need to find a way to switch colorscheme back to blue if in maps mode.
Gwe89
Re: Nx patch
Post by Gwe89 »
Go4IT wrote: 14 Jan 2020, 07:47 Right, this looks terrible. Somebody of us need to find a way to switch colorscheme back to blue if in maps mode.
Yes or swap the blue theme to the dark
I think I may have put the wrong file up it may be password protected zip if any problems give me a shout
Also custom logos can be done on the nav but m0tral wont do them because he cannot protect it 😂
Shame it cannot be done on the MCA as he told me it was cut from the latest firmware for the MCA prob why it only shows the time and date when in standby
paxtonix
Re: Nx patch
Post by paxtonix »
Color definition is located at :
F_HS_RVC\FGS.DNL(004E044C to 004E0B6E)
FORD_HSR\FGS.DNL(004D6F74 to 004D768A)
for files
-CRC32: last 4 bytes of DNL, ULI, BIN, ELF files.(reverted byte order)
-CRC16: last 2 bytes of voice PKG files on MAP DVD "\CFG\VOICE".(reverted byte order)
-version number in offset: file size - 22 bytes
Issue is in Airco panel - colors used to display the car-shape are the same as colors used to display map. Shades for different color palet is diferent in dark and blue theme.
described quite time ago :?
Does Flash have additional space for "extra" color palet ?
Tourist
Gwe89
Re: Nx patch
Post by Gwe89 »
Fx, nx, mca
I have never tried the fx
ronald0001
Re: Nx patch
Post by ronald0001 »
with this patchfor fx you can also use maps wich are downloaded from the internet
Gwe89
Re: Nx patch
Post by Gwe89 »
ronald0001 wrote: 15 Jan 2020, 20:03 with this patchfor fx you can also use maps wich are downloaded from the internet
Yes this is what the patch is for
Re: Nx patch
Why not find the point go get around the copy-protection ourselfs instead of distributing files from the net? :D
Gwe89
Re: Nx patch
Post by Gwe89 »
Go4IT wrote: 16 Jan 2020, 06:21 Why not find the point go get around the copy-protection ourselfs instead of distributing files from the net? :D
But we already have the files
