How to switch car mode (Mondeo, Focus) for FX
Firmware is all the same in FX, NX and MCA units, regardless of car it is used. But there must be some Board ID or coding (maybe via the serial...) which makes some differences like the light-control.
oscarboiro
Re: Repair FX, NX satnav units not starting anymore
Post by oscarboiro »
Go4IT wrote: 03 Jan 2020, 16:40 Glad you found it! :D
Is interesting switch mondeo to focus and viceversa, the Ucds have this option to Sony radio. In theory, if I write backup from focus2 to mondeo unit, this unit work always in mondeo mode? Or worn in focus mode? Today I connect my fx in my home kuga installation and don’t have communication in can bus, in mondeo the can bus signal are in mms can?
Kuga MK1 owner
User avatar
Stevebe
Post by Stevebe »
Yeah the MMCAN 125K
Digimod
oscarboiro wrote: 04 Jan 2020, 00:56 In theory, if I write backup from focus2 to mondeo unit, this unit work always in mondeo mode? Or worn in focus mode?
I couldn't get behind this secrect, but stopped investigating because lack of time. Sooner or later i will find out. It is not the firmware, i know. Also not the Board-Id? My best guess for now is that it belongs to the Modelnumber.
DGAlexandru
Post by DGAlexandru »
Doesn't that 507 sector contain also the Model Number?
Maybe a 507 sector change and then a FW update to have also the other chip reflashed will do the trick.
drobec.eu
Starter
Post by drobec.eu »
Mondeo and Focus have different configuration in illumination button NAVI.
On Mondeo configuration illumination button operate via CAN.
On Focus configuration illumination button Via cabel...
If you need change configuration FOCUS to Mondeo need rewrite Flash sector 507. On sector 507 in flash is configuration and PIN.
On Mondeo is eeprom blank on FOCUS is eeprom full...
If your need change configuration Mondeo to FOCUS need rewrite Flash sector 507 and EEprom.
Must have EEprom and flash sector 507 on Mondeo Navi and FOCUS Navi. If you have this you can change configuration Navi ...
If you no know PIN enough rewrite sector 507...
Sorry for my english... :(
DGAlexandru
From what I remember if you clear an EEPROM then at next boot it will be "repaired" but you loose all the stored settings like radio stations, volume / DSP presets, NAVI addresses and so on.
drobec.eu
Starter
Post by drobec.eu »
DGAlexandru wrote: 04 Jan 2020, 21:32 From what I remember if you clear an EEPROM then at next boot it will be "repaired" but you loose all the stored settings like radio stations, volume / DSP presets, NAVI addresses and so on.
Maybe enough rewrite only sector 507 in Flash...
when I change the configuration I always rewrite sector 507 and EEprom...
You remember right. The EEPROM will be rewritten with a default which is placed somewhere in Flash.
Sector #507 (not #509) contains the serial (last 7 digits of label) of an NX.
On FX it's sector #251, because it's flash is only half size of NX (32 MB).
drobec.eu wrote: 04 Jan 2020, 21:29 On Mondeo is eeprom blank on FOCUS is eeprom full...
On Mondeo it's also filled and used, there is no difference.
