How the secondary bootloader (SBL) works
This thread is to research how the SBL works. It is used for updating the Convers+ and will get downloaded from a VBF file using UDS into the RAM of the MAC7116 and get's called afterwards.
It then takes over control of the whole Convers+ plattform. It's main purpose the is to communicate with the updater, erase the Flash und program the downloaded new one into it.
... to be continued ...
DGAlexandru
Re: How the secondary bootloader (SBL) works
Post by DGAlexandru »
IPC with PBL and FW from a FaceLift version.
SBL sent with IPC Updater when selecting "EEPROM Edit", and as soon as it starts to download EEPROM contents I put CPU (MAC7116) into Halt mode and then downloaded its RAM content.
As you can see in the 2 attached dump files, the SBL is loaded in RAM at address 0x0FF8.
For disassembling the code I've used the entire (RAM) file.
DGAlexandru wrote: 30 Dec 2019, 15:10 As you can see in the 2 attached dump files, the SBL is loaded in RAM at address 0x0FF8
This must be an offset, because the 48kb RAM starts at 0x4000 0000 up to 0x4000 BFFF.
DGAlexandru
OK mr. :) 0x40 000 FF8 in RAM
0x0FF8 is the offset in the file I have uploaded, file that represents the entire RAM.
