Update IPC
drobec.eu
Starter
Re: Update IPC
Post by drobec.eu »
I also searched convershacker program but not found... :? :cry:
paxtonix
Re: Update IPC
Post by paxtonix »
HI guys
I have also successfuly clone an IPC with ursadon soft . Great work.
Now since I have them all dumped , I'll try with my friends to play with it in IDA , to see is there a solution to crack the vin number in it, so additional PDC /battery and temp will work withoun entering wrong vin in to BCM .
Tourist
Re: Update IPC
Hack the hacker :lol: Good luck!
paxtonix
Re: Update IPC
Post by paxtonix »
Go4IT wrote: 05 Nov 2019, 20:41 Hack the hacker :lol: Good luck!
What so funny about it :D , Just think outside the box ;) ,
Software was crack open once - So what is standing on the way, to make our own test's with it ?
Let's try to continue what Ursadon started for all of us... :)
Hope he will show up .. Lot of questions to ask ;)
Tourist
Artist
Re: Update IPC
Post by Artist »
You didn't understand Go4it ...
He didn't mean it the way you understood it, if you actually understood it as it was understood ...
All this GREAT forum is about that! Share the results with others ...
Re: Update IPC
Now, i understand nothing ... :lol: :lol:
All fine guys, let's go on with the work!
paxtonix
Re: Update IPC
Post by paxtonix »
@ artist - I got you :)
but speaking of which, currently searching to calculate the soft CRC. Tried to change the main logo but after upload to ipc it gives me Rom level -FAIL.
don't know how to calculate the CRC for it :( IPC seems to work ok , and the logo is on main screen
What am I doing wrong ?
Tourist
drobec.eu
Starter
Re: Update IPC
Post by drobec.eu »
No must have correct CRC... IPC work very good whithout correct CRC.
User avatar
Stevebe
Re: Update IPC
Post by Stevebe »
Go4IT wrote: 06 Nov 2019, 17:55 Now, i understand nothing ... :lol: :lol:
Yeah I’m glad I’m not the only one
Digimod
Gwe89
Re: Update IPC
Post by Gwe89 »
paxtonix wrote: 06 Nov 2019, 18:10 @ artist - I got you :)
How have you changed the logo?
