How to recover bricked Convers+ (SOLVED)
Artist
Re: Ako obnoviť murované Convers + (vyriešené)
Post by Artist »
I also tried this and it didn't work.
But when I replaced the paired flash with Mcu, it worked ...
Try to...
Re: How to recover bricked Convers+ (SOLVED)
To be clear, it worked before but had issues with the MM CAN, then i desoldered the MAC using and IR Reworkstation, cleaned all the pads using soldering braid and soldered the chip back using leaded soldering tin. After that the chip won't start up again. I could start JTAG connection, but as soon as the J-Flash tries to store it's downloadcode into the chips internal SRAM it failed with an errormessage telling it can't.
I now fear it somehow killed the chip...
Artist
Post by Artist »
It must be a coincidence ...
The infrared station is completely up.
I also managed to damage the MCU during preheating and quick replacement ...
Once I inadvertently knocked down a small resistance from the MCU. It needs to be checked properly. It happens ...
Gwe89
Post by Gwe89 »
drobec.eu wrote: 20 Oct 2019, 13:22 If you need copy,erase,program flash on MAC use J-tag you must have Jumper (Bridge) :
This pad here is 5v
User avatar
Stevebe
Post by Stevebe »
now we need to read the flash
Digimod
