Ford Mondeo MK4 CAN-DB
sanndo
Re: Ford Mondeo MK4 CAN-DB
Post by sanndo »
Go4IT wrote: 05 Apr 2021, 16:27 ...
It is send from IPC on D0 Bit 5, so sending 0x00 means IGN-OFF and 0x20 IGN-ON.
Thank you!!
ZvonimirG
Starter
Post by ZvonimirG »
MS CAN
ID 050 DLC 8 00 00 00 00 00 00 00 X0
4
key battery low message
8
Position light indicator
C
Position light indicator and key battery low message
ID 050 DLC 8 00 00 00 00 00 00 00 0X
1
Green UP arrow
2
Red UP arrow
ZvonimirG
Starter
Post by ZvonimirG »
ID 06B DLC 8 00 00 X0 00 00 00 00 00
4 Rear Fog On
0 Rear Fog Off
ID 06B DLC 8 00 00 00 00 00 0X 00 00
4 Long Beam On
0 Long Beam Off
ID 06B DLC 8 00 00 00 00 00 X0 00 00
1 Handbrake On
0 Handbrake Off (For Handbrake indicatror to be turned off also must be present can id 0x200 with value 0x80 in last byte, maybe brake fluid level?)
ID 06B DLC 8 00 00 00 00 00 00 X0 00
0 Bonnet and Luggage open
1 Bonnet open
2 Luggage open
3 Bonnet and Luggage closed Front Fog off
8 Front Fog on, Bonnet and Luggage open
9 Front Fog on, Bonnet open
A Front Fog on, Luggage open
B Front Fog on
ID 06B DLC 8 00 00 00 00 00 00 0X 00
0 all doors open
1 front left door closed other doors open
2 front right door closed other doors open
3 front doors closed rear doors both open
4 rear left door closed other doors open
5 left doors closed, right doors both open
6 front left and rear right open other doors closed
7 rear right door open other doors closed
8 rear right door closed other doors open
9 front left and rear right closed other doors open
A right doors closed, left doors both open
B rear left door open other doors closed
C front doors both opened, rear closed
D front right door open, other doors closed
E front left door open, other doors closed
F all door closed
ID 06B DLC 8 00 00 00 00 00 00 00 0X
0 indicators off
1 Left indicator
2 Right indicator
3 left and right indicator
ZvonimirG
Starter
Post by ZvonimirG »
Battery warning light
ID 220 DLC 8 X0 00 00 00 00 00 00 00
0 Battery light Off
1 Battery light ON
ID 220 DLC 8 00 0X 00 00 00 00 00 00
0 No Error
1 Engine malfunction Yellow Error
2 Engine malfunction Red Error
4 Diesel filter overloaded msg
8 Diesel filter overloaded msg with chime
ID 220 DLC 8 00 00 0X 00 00 00 00 00
0 Red Engine Malfunction and CEL light
4 Red Engine Malfunction
8 CEL light
C No error
ID 220 DLC 8 00 00 00 0X 00 00 00 00
0 CEL lamp Off
4 CEL Lamp On
8 CEL Lamp Flash
Great findings @nutra, i'll incorporate them. I still look for a good tool to document those stuff. But did not find anything better than Google Docs until now:-(
ZvonimirG
Starter
Post by ZvonimirG »
MS CAN
ID 110 DLC 8 00 00 00 00 00 00 0X 00
0 No Msg
1 Factory Mode
2 Factory Mode Paused
3 Transport Mode
4 Transport Mode Paused
5 Crash Mode
7 Normal Mode
ZvonimirG
Starter
Post by ZvonimirG »
MS CAN Oil Service msg
ID 280 DLC 8 00 00 00 00 X0 00 00
0 No Msg
1 Oil Change Msg
2 Service: Oil Reset Complete
3 Service: Oil Reset In Progress
ZvonimirG
Starter
Post by ZvonimirG »
MS CAN
ID 010 DLC 8 X0 00 00 00 00 00 00 00
0 No Msg
8 Brake Module Misbuilt msg
ZvonimirG
Starter
Post by ZvonimirG »
MS CAN
Handbrake indicator (in conjuction with ABS Fault)
ID 048 DLC 8 X0 00 00 00 00 00 00 00
F Handbrake indicator Off
E Handbrake indicator ON
ABS Lamp
ID 048 DLC 8 0X 00 00 00 00 00 00 00
9 ABS Lamp On
A ABS Lamp Slow Flash
C ABS Lamp Quick Flash
F ABS Lamp Off
ESP Off
ID 048 DLC 8 00 X0 00 00 00 00 00 00
7 No Msg
8 ESP Off Msg
ESP Lamp
ID 048 DLC 8 00 0X 00 00 00 00 00 00
C ESP Lamp On
5 ESP Lamp Quick Flash
6 ESP Lamp Slow Flash
7 ESP Lamp Off
Cruise Control (Tempomat)
ID 048 DLC 8 00 00 X0 00 00 00 00 00
6 CC Off
A CC Stand By
E CC Active
ZvonimirG
Starter
Post by ZvonimirG »
MS CAN
PTC Heater
ID 078 00 00 0X 00 00 00 00 00
0 PTC Off
1 10%
2 20%
3 30%
4 40%
5 50%
6 60%
7 70%
8 80%
9 90%
A 100%
