IPC Software
DGAlexandru
- Pro
Re: IPC Software
FW 15xx is where I want to go too, at least for FL version of C+.
We should be able to move the extra functions from an older FW to this new one as soon as we dissasemble them a little more.
Re: IPC Software
please help me,what its last Fw for this unit?
Re: IPC Software
You have fw1010 ucds crack for this model?
DGAlexandru
- Pro
Re: IPC Software
Ah.. OK.. From your first question I understood that you want to go with Original FW (and patronix understood the same).
You need to use 1122 vFL.
1122 was last original FW version for second generation of C+ (also called Middle FL or mFL), those with P/N starting with A. They look the same with first generation of C+, but have FW that expects RCM module to be on HS-CAN and BCMII acting as a gateway for them.
The m0 tr al version 1122 vFL uses the original 1122 FW to add his addons and deactivates the C+ original functions that controll the AirBag LED and instead he put a function to light it up on C+ boot.
Re: IPC Software
Im upload this version vFL1122 to my convers and no working good
DGAlexandru
- Pro
Re: IPC Software
There is something weird with those C+ - their manufacture date is 2017.
Did you saved the original FW? If yes, post the files here so we can have a look.
Also, put a picture of the PCB.
Re: IPC Software
last is 1010 for 8Uxxxxx
better future with childrens
Re: IPC Software
exist m0tral fw mod version 1007 or 1010?
Re: IPC Software
I would say looking at your picture you have a preface mod on to a middle convers
You will need the middle convers mod
Other wise it will look flaky
Digimod
