H@ve you tried conversmod.de
Update IPC
Re: Update IPC
thenx
is there another option?
thenx
t.
thenx
t.
Re: Update IPC
New release
1.1.0
## [1.1.0] - 2019-06-20
### Fixed
- Progressbar flickering
- Moved serialport to other thread, so UI now is not lagged
- More error handling
### Added
- Display current transfer speed in statusbar
1.1.0
### Fixed
### Added
Not native English speaker
Re: Update IPC
New release
1.2.0
## [1.2.0] - 2019-06-23
### Fixed
- Minor UI bugs
### Added
- Dumping ROM / Flash / EEPROM
- Reset IPC from menu
- Auto select bootloader from "Firmwares/" folder
I think we need to rename the project, because from the program-flasher we get a combine
1.2.0
### Fixed
- Minor UI bugs
### Added
Re: Update IPC
what FW version its on flash folder?
its original 1412?
thenx
its original 1412?
thenx
Re: Update IPC
its r1007 for preFL
I don't tested on FL, because i don't have it
Look at this table, for aviable fw to download:
https://docs.google.com/spreadsheets/d/ ... iEjqXA7Zbo
Re: Update IPC
thenx
i have FL converse+
you have too modify FW version with new function?
i have FL converse+
Re: Update IPC
i have elm327 cabel with this driver CH340T driver
https://fordcom.de/elm327-treiberdownload/#
i dont conect with you soft
can you help me?
thenx
can you help me?
thenx
Re: Update IPC
tried v1.2.0 with FL14xx reads eeprom fine the file i loaded intp EEprom direct is on left the file read with your reader on rightUrsadon wrote: ↑23 Jun 2019, 14:51 New release
1.2.0
### Fixed
- Minor UI bugs
### Added
I think we need to rename the project, because from the program-flasher we get a combine![]()
this was a Diesel convers 14xx a converted to Petrol so has moded code. the mph to kmph as you know 097 00p 01 km i think i have found the flagg byte
for the 6k Diesel 8k petrol ill confirm later.
Digimod
