Blis
Gwe89
Re: Blis
Post by Gwe89 »
avladimir wrote: 07 Dec 2020, 18:46 If memory serves me right there are two kinds of BCMs: 2.2 TDCi and the rest.
The part numbers should be:
- BG9T-14A073-Yx -> without TPMS
- BG9T-14A073-Xx -> with TPMS
similarly, for all other engines:
- BG9T-14A073-Dx -> without TPMS
- BG9T-14A073-Cx -> with TPMS
Replacement BCMs can only be ordered with TMPS, as far as I have observed.
There is no mention on BLIS on the BCMs so it should be safe to assume that all facelift BCMs have the private CAN built in.
I think the one fitted to my car is BG9T-14A073-BH
Think I need to get it all wired up and test it before I buy a bcm as there not cheap and would need to pay ford to program it
avladimir
Starter
Re: Blis
Post by avladimir »
If your car is not 2.2 diesel, then Bx might be the one without TPMS and Cx is with TPMS. I think Dx is on pre-Facelift.
Gwe89
Re: Blis
Post by Gwe89 »
avladimir wrote: 08 Dec 2020, 11:13 If your car is not 2.2 diesel, then Bx might be the one without TPMS and Cx is with TPMS. I think Dx is on pre-Facelift.
So possibly my bcm will support blis?
avladimir
Starter
Re: Blis
Post by avladimir »
yup. absolutely. See if you have the corresponding pins on the BCM. If they are, there are very good chances to work.
Again, ETIS does not says something about BLIS in particular on the BCM, so you should be fine.
Gwe89
Re: Blis
Post by Gwe89 »
avladimir wrote: 08 Dec 2020, 13:25 yup. absolutely. See if you have the corresponding pins on the BCM. If they are, there are very good chances to work.
Thank you had a look and my bcm has the pins, mine is BK
Re: Blis
You are absolutely right with all three statements :D
Those "X-Parts" replace all subparts and integrate every function.
Gwe89
Re: Blis
Post by Gwe89 »
BG9T-14A073-BL no resistance on the 3RD-CAN pins
I would possibly say the same with the one fitted to my car which is BG9T-14A073-BK
Gwe89
Re: Blis
Post by Gwe89 »
Gwe89 wrote: 23 Dec 2020, 17:42 20201223_173402.jpg
When I check HS-CAN & MS-CAN pins i get 120ohm so I guess blis enabled cars use a certain bcm part number as i get nothing on both 3RD-CAN
Gwe89
Re: Blis
Post by Gwe89 »
Anyone know a part number for a 2.0tdci that had blis
Gwe89
Re: Blis
Post by Gwe89 »
BG9T-14A073-CL
I found this one but I'm not sure
