Page 4 of 7
Re: Ford Mondeo MK4 CAN-DB
Posted: 13 Mar 2020, 20:16
by Go4IT
Just wonder if there is a IGNITION status on the HS-CAN via some ID from BCM...
Posted: 14 Mar 2020, 09:26
by amplified
Forscan detects all statuses of the ignition key via BCM, but haven't searched for PID
Posted: 14 Mar 2020, 16:51
by ronald0001
Go4IT wrote: ↑13 Mar 2020, 20:16
i will take a look later on hs can to find ign status on hscan....
with raspberry and candump its easy to find changes...cuz they are shoen in different color (this case red)
Posted: 31 Aug 2020, 21:27
by Gwe89
I have made a start on translation I hope others help also, I will add any information I know also
Posted: 18 Jan 2021, 13:07
by DGAlexandru
UP!
I want to develop an application in order to simulate all the messages that IPC needs over MS-CAN in order to improve our IPC bench tests.
The topic about it is here, on this forum:
viewtopic.php?f=25&t=231
If you have any CAN decoded messages that are not present in the google document that G04IT has started (link in first message in this topic), please share them.
Posted: 21 Mar 2021, 19:03
by sanndo
Wondering, is there a ignition over MM-CAN?
Posted: 02 Apr 2021, 12:54
by Stevebe
sanndo wrote: ↑21 Mar 2021, 19:03
Yeah on mk4 its on mm can
Posted: 02 Apr 2021, 16:27
by sanndo
Stevebe wrote: ↑02 Apr 2021, 12:54
Did you know ID?
Posted: 02 Apr 2021, 18:11
by Stevebe
sanndo wrote: ↑02 Apr 2021, 16:27
Did you know ID?
Id 048 FF 07 6C 09 27 02 E0 A0
Posted: 05 Apr 2021, 16:27
by Go4IT
No, steveb, that's wrong. You posted the ID from MS-CAN, but he want's
MM-CAN.
There you find ignition in form of a boolean at
Code: Select all
ID DLC D0 D1 D2 Period (ms)
285 3 60 00 00 125
It is send from IPC on D0 Bit 5, so sending 0x00 means IGN-OFF and 0x20 IGN-ON.
