Vin protection
paxtonix
Re: Vin protection
Post by paxtonix »
Yep, Theory was right.
I was able to decrypt files. DES-CBC algorithm is used for encryption. So we are one step forward boyz
Code: Select all
https://tools.ietf.org/html/rfc2405
Tourist
User avatar
Stevebe
Re: Vin protection
Post by Stevebe »
leader wrote: 09 Jan 2020, 08:30 . With a simple bash script you can regenerate the whole firmware from the CAN messages....
are you running Linux / OSX
Digimod
DGAlexandru
Re: Vin protection
Post by DGAlexandru »
I did clean the LOG it with Notepad++ then copy the HEX values in HXD... so it can be done in Win too.. or Phyton script.... there are many options today :)
User avatar
Stevebe
Re: Vin protection
Post by Stevebe »
DGAlexandru wrote: 12 Jan 2020, 21:14 I did clean the LOG it with Notepad++ then copy the HEX values in HXD... so it can be done in Win too.. or Phyton script.... there are many options today :)
Yeah so I am beginning to see, I wish I had started to study code when I was younger lol. You guys amaze me_
Digimod
User avatar
Stevebe
Re: Vin protection
Post by Stevebe »
leader wrote: 09 Jan 2020, 00:43
The VBF files are stored as resource in the MondeElmLoader.exe file. So you need to open the exe with a Resource Editor and save the firmwares with it.
Can I ask which resource editor to use as the one I have does not shown the resource data
Digimod
DGAlexandru
Re: Vin protection
If you have old version of ELMLoader, that is unencrypted, you can go even with online .NET dissasemblers.
User avatar
Stevebe
Re: Vin protection
Post by Stevebe »
DGAlexandru wrote: 13 Jan 2020, 07:13 If you have old version of ELMLoader, that is unencrypted, you can go even with online .NET dissasemblers.
The old version Of the mondeoElmLoader jet rains will open the file and enable yu to export the data
https://www.jetbrains.com/decompiler/do ... standalone and
https://www.telerik.com/products/decompiler.aspx
seems to work on most and if you run vis studio 17 these will intergrate hope this will help others
Digimod
leader
Contact:
Re: Vin protection
Post by leader »
Stevebe wrote: 12 Jan 2020, 18:12
Yes, I mainly work on Linux and OSX (with GNU tools).
leader
Contact:
Re: Vin protection
Post by leader »
Stevebe wrote: 13 Jan 2020, 00:06
You can simply use dnSpye disassambler to extract resource also.
User avatar
Stevebe
Re: Vin protection
Post by Stevebe »
Leader
Another easy way to obtain the modified firmware is to use the MondeoElmTester program which will read the content of the firmware from the IPC and stores all the CAN messages int the log file. With a simple bash script you can regenerate the whole firmware from the CAN messages....
Based on m0rtal's tester program I also created my little program to read/write the vbs files and now there is the IPC Updater tool developed here on the forum which can also read the firmware from any Convers+ IPC
i no nothin
Digimod
