Page 21 of 34
Posted: 10 Jan 2020, 09:35
by tomy75
what is the difference between themes FL and M? I use the black theme in the FL version of the convers. Which theme should I choose for the correct image color?
Posted: 10 Jan 2020, 11:30
by Ursadon
Gwe89 wrote: ↑10 Jan 2020, 09:32 Does the new wallpaper put logo before 120000
Are you using the latest version (1.3.0)? I tested for vFL - all ok, also FL image looks like it is correctly generated
tomy75 wrote: ↑10 Jan 2020, 09:35 what is the difference between themes FL and M? I use the black theme in the FL version of the convers. Which theme should I choose for the correct image color?
Different color codes. Try to use Theme 1 FL
Posted: 10 Jan 2020, 11:31
by DGAlexandru
FL = FaceLift Convers+ -> those that have P/N starting with BS7T or CS7T
M = Middle Convers+ (late 2009 - 2010) -> those that have P/N starting with AM2T or those that have "M0 tr al" FW and have P/N starting with 7M2T / 8M2T.
There is a slight difference in them.
Posted: 10 Jan 2020, 11:52
by tomy75
im use Theme 1 FL
on black them ist color no good,but with bleu theme its ok,
i need use black theme what can i setting in convershacker?i need use bgr pallete?
thenx
Ursadon wrote: ↑10 Jan 2020, 11:30
Posted: 10 Jan 2020, 12:03
by Gwe89
But what's the offset4main 30120000 is that the bytes you put into main? 30 12 00 00
Posted: 10 Jan 2020, 12:05
by Ursadon
Gwe89 wrote: ↑10 Jan 2020, 12:03 But what's the offset4main 30120000 is that the bytes you put into main? 30 12 00 00
Yes. In Firmware/ folder you can find already modified .vbf for MainFW with calculated checksums
Posted: 10 Jan 2020, 20:00
by ronald0001
Ursadon wrote: ↑10 Jan 2020, 12:05
means no change of offset needed in flash of original picture?
Posted: 10 Jan 2020, 22:11
by Stevebe
There’s no arm-in-it
Preface
Posted: 10 Jan 2020, 22:47
by Gwe89
Hey notice an error, if the file that's made with the convert image is over 130kb it fails to load in ucds
Also you can see on the logo its missing some at the bottom
Posted: 11 Jan 2020, 19:41
by DGAlexandru
Yes, the VBF that is created with Convert Image has a "static vbf file header" that erases and then writes only 2 sectors, each with 0x01 00 00 bytes (65.536 bytes) or 64kb.
You should be able to repair the VBF by changing in a HEX editor the header, from 0x02 to 0x03: just after 0x7D ("}" in text mode) you have 0x30 0x12 0x00 0x00 (start address) then 0x00 0x02 0x00 0x00 (number of bytes to erase then write).
Convers Hacker is a tool that helps you do some things more easy or helps you understand how to do some things.. it doesn't do everything as there are a lot of versions of Main and Extended Flash configurations that should be taken into consideration which would take too much developing time.
