what is the difference between themes FL and M? I use the black theme in the FL version of the convers. Which theme should I choose for the correct image color?
Are you using the latest version (1.3.0)? I tested for vFL - all ok, also FL image looks like it is correctly generated
Different color codes. Try to use Theme 1 FL
Not native English speaker
DGAlexandru
- Pro
FL = FaceLift Convers+ -> those that have P/N starting with BS7T or CS7T
M = Middle Convers+ (late 2009 - 2010) -> those that have P/N starting with AM2T or those that have "M0 tr al" FW and have P/N starting with 7M2T / 8M2T.
There is a slight difference in them.
im use Theme 1 FL
on black them ist color no good,but with bleu theme its ok,
i need use black theme what can i setting in convershacker?i need use bgr pallete?
thenx
thenx
Yes. In Firmware/ folder you can find already modified .vbf for MainFW with calculated checksums
ronald0001
- Active member
means no change of offset needed in flash of original picture?
There’s no arm-in-it
Preface
Digimod
Hey notice an error, if the file that's made with the convert image is over 130kb it fails to load in ucds
Also you can see on the logo its missing some at the bottom
DGAlexandru
- Pro
Yes, the VBF that is created with Convert Image has a "static vbf file header" that erases and then writes only 2 sectors, each with 0x01 00 00 bytes (65.536 bytes) or 64kb.
You should be able to repair the VBF by changing in a HEX editor the header, from 0x02 to 0x03: just after 0x7D ("}" in text mode) you have 0x30 0x12 0x00 0x00 (start address) then 0x00 0x02 0x00 0x00 (number of bytes to erase then write).
Convers Hacker is a tool that helps you do some things more easy or helps you understand how to do some things.. it doesn't do everything as there are a lot of versions of Main and Extended Flash configurations that should be taken into consideration which would take too much developing time.
