How to gain firmware of PAM module BS7T-15K866-AE ?
peter
Starter
Re: How to gain firmware of PAM module BS7T-15K866-AE ?
Post by peter »
in a few days I will be able to play andruino. an elegant solution is a gateway and appropriate software. nice to see the gateway inside. but a less elegant solution for autopam is speed reading grom CAN and activation through the attached cable to the PAM button. activation by Reverse signal can also activate the reverse lamp.
DGAlexandru
Post by DGAlexandru »
If you have "MLoaderPAM.exe" we can extract the FW from it :roll: :P
.. but all the exe files I got from different users are the same and contain only oficial FW in order to make older PAM HW work with Convers+ (to send the needed info on CAN MS)
DGAlexandru wrote: 25 Dec 2019, 16:10 .. but all the exe files I got from different users are the same and contain only oficial FW in order to make older PAM HW work with Convers+
This is exactly what i told a few posts before ;) Auto-PAM is triggered from a modded Convers+, not from the module itself. To proof, someone having it could revert to a standard Convers (or firmware downgrade) and the function should stop.
I think Alexey use some service routine calls to activate the PAM.
Gwe89
Post by Gwe89 »
Go4IT wrote: 25 Dec 2019, 16:15
It works from my gateway box, if I change convers it still works, when I unplug the gateway my parking sensors won't work at all the light on the button will just flash
Ok, then it is this small Arduino doing the job.
Gwe89
Post by Gwe89 »
Go4IT wrote: 25 Dec 2019, 18:17 Ok, then it is this small Arduino doing the job.
Yes also what ever m0tral edited in the pam firmware, because when I got autopam there is a loader that programs the pam module hence why the dam thing won't work if my gateway fails, luckily it no longer fails after changing it from nano to uno
drobec.eu
Starter
Post by drobec.eu »
DGAlexandru wrote: 25 Dec 2019, 16:10 If you have "MLoaderPAM.exe" we can extract the FW from it :roll: :P
Gwe89
Post by Gwe89 »
drobec.eu wrote: 25 Dec 2019, 19:58
They are for pam update not the autopam and I have looked and he has encrypted his new loaders but I have been told that when you run the loader and it says firmware files prepared it is somewhere on the pc
Gwe89
Post by Gwe89 »
@ go4it if I program a pam module with the loader and send you it would it be any use to you? Or even send you the loader files?
Gwe89 wrote: 25 Dec 2019, 23:33 @ go4it if I program a pam module with the loader and send you it would it be any use to you?
No, as we already found out, the PAM is simply updated to a genuine recent one. The magic all is in the gateway. So we need an HEX dump of it's Flash or trigger the interface and look how it behaves. For the first it would also be finde to have some CAN logs when PAM get's activated.
