Update IPC
User avatar
Stevebe
Re: Update IPC
Post by Stevebe »
Hi guys thank you for the guidance, I understand The proses now, I just never used the therm SEED before, it is a simple principle that seem to be very effective, from reading a lot of articles on this matter it would seem it’s going to get a lot more secure with the use of newer and better cryptography, hardware.. when I was learning Canbus did not exist so I have only been working with it for past 2 years, and being a old person things take longer to sink in, LOL..
Know I have more info I’ll go through all the posted info and I’m certain I’ll understand it better,
Once again thanks for taking the time to explain..
Digimod
User avatar
Ursadon
Re: Update IPC
Post by Ursadon »
Okay, today I wrote a program (proof-of-concept) that successfully erased flash and wrote a new
When the flash is clean, the IPC is always restarts (aka "bootloop")
i'm using ELS27 cable (ELM327-compatible) with some sort of "tuning" - in driver page, need to change timeouts from 16ms to 1ms, otherwise the upgrading process takes more than 1 hour.
For erasing flash i used "RoutineControl" = 0x31 with "RoutineControlType" = 0x01 (startRoutine) and "routineIdentifier" = 0xFF 0x00 (p.290 ISO14229 - ""eraseMemory"")"
Detailed update log is here - https://docs.google.com/spreadsheets/d/ ... sp=sharing
Also, i scanned Ford DSFM site (https://www.fordtechservice.dealerconne ... roduct=IDS) in order to search for new IPC firmwares. I put the data in the table:
Not native English speaker :cry:
oscarboiro
Re: Update IPC
Post by oscarboiro »
Ursadon wrote: 25 May 2019, 16:38
oscarboiro wrote: 30 Apr 2019, 08:49
After copy on my arduino sketch have this error: expected initializer before 'LFSR'
i need a LFSR library? the code are only to C# or is valid to arduino?
Hi! I apologize for the delay - I finished my studies at the institute :)
This is pseudo C code
Here is C code, which you can use - https://gist.github.com/Ursadon/8c55972 ... efa037fabb
Also:
1) I cracked all secret keys for (probably) all modules in Ford - https://gist.github.com/Ursadon/8941ff5 ... e09f060eec
For IPC use second key.
2) I made my own CANhacker, so the development process will go faster :)
Thanks!!! but i have a very lower level to program and after "COpy and Paste" your code my arduino sketch dont work to calculate seed.
i made array with can bus code, example; 720 8 23 24 25 26 27 28 23 24
array(0) = 23
array(1) = 24
array(2= = 25 ....
i take only a digits of a seed and need send to your code to calculate outcode, but i dont know to do.
this is my code to read CAN BUS
CAN0.readMsgBuf(&rxId, &len, rxBuf);
and to filter signals i wrote this:
if (rxId == 0x433) {
if (rxBuf[3] == 0x0A) {
//Here code to execute action
any sugestion to put your code to calculate seed?
thanks
Kuga MK1 owner
Re: Update IPC
Extreeem goood job, Ursadon!! :D I'm really impressed and can't wait to test your work.
User avatar
Stevebe
Re: Update IPC
Post by Stevebe »
Ursadon wrote: 04 Jun 2019, 18:10 Okay, today I wrote a program (proof-of-concept) that successfully erased flash and wrote a new
brillient work, would it be possible try your perogram,
Digimod
User avatar
Ursadon
Re: Update IPC
Post by Ursadon »
oscarboiro wrote: 05 Jun 2019, 11:49
Also:
array(0) = 23
array(1) = 24
array(2= = 25 ....
I'm not very familiar with AVR C compiler, but you have a problem with passing the filter to the function because of arrays? if so, then just combine "char[*]" into int32:
uint32_t seed = (static_cast<int>(array[0]) & 0xff) << 24
| (static_cast<int>(array[1]) & 0xff) << 16
| (static_cast<int>(array[2]) & 0xff) << 8
| (static_cast<int>(array[3]) & 0xff) ;
and then pass to "int generate_seed_response(int s1, int s2, int s3, int s4, int s5, int seed)" function
s1-s5 keys seems to be a "{0x08, 0x30, 0x61, 0x55, 0xAA}" (most likely)
Stevebe wrote: 05 Jun 2019, 20:31
I only tested the flashing external memory. I’m still afraid to overwrite the main one - if anything, I don’t have a second panel :)
That is why I ordered the panel from the diesel mondeo, which will come in 4-6 working days. Then I will release v1.0.0 and continue to work on the ford logo image changer (the "FLIC" project). :)
User avatar
Ursadon
Re: Update IPC
Post by Ursadon »
Version 1.0.0 (codename: "Proof-of-concept") is released. For ELS27 cable.
IPCupdater-1.0.0.zip
Pre-flight check:
1. Use ELS27Baudrate.exe to set port speed to 2MBit/s
ELS27_Baudrate.zip
2. On driver page set latency to 1 ms (otherwise update procees takes over 1 hour):
Current major bugs:
During update process don't touch mouse (because program is single-thread, i'll fix it later)
ToDo:
1. Multi-threading
2. Fix latency
3. Auto select port speed
4. More error handling
5. Add support for ELM327 (dont' use STN1170-specific commands)
6. Fix progressbar flickering
7. Show SW number before and after updating
User avatar
Stevebe
Re: Update IPC
Post by Stevebe »
Ursadon
do i need to instal QT brfore the ipcupdater will run as i get a error cant fing QT, or do i need to register the DLL files
it looks really good
Digimod
User avatar
Ursadon
Re: Update IPC
Post by Ursadon »
Stevebe wrote: 10 Jun 2019, 00:05 Ursadon
Sorry, i forgot some lib :oops:
IPCupdater-1.0.0-withlib.zip
tomy75
Re: Update IPC
Post by tomy75 »
hello
i need modifiy FW patch for my FL convers,i have car from FL
can you please help?
thenx
