Repair FX, NX satnav units not starting anymore
oscarboiro
Re: Repair FX, NX satnav units not starting anymore
Post by oscarboiro »
Hello Friends, and happy new year to all members.
Now i have another FX with fault, i read the voltage values, and the MAX834(AAAX) have next values:
-Output: 3,35V
-Input: 1,54V
In the picture with labels, have 4V in the input and i have 1,54v, any suggestions?
Kuga MK1 owner
Try to replace the part, as it may also be defective like mine was...
oscarboiro
Ok, now I'm going to buy some parts(in few weeks i recieve it). I have my broken nx after stopping the update process and I don't start anymore, I read values from nx defective ​​and I have the same values. But first I try to replace it, and if work, i replace the same part on my nx. Thank you!!!
Kuga MK1 owner
oscarboiro
Hello, im looking my 2 nx and test the voltage in MAX834 and all have the same values.
-Output: 3,35v
-input: 1,54V
My two NX work fine, and i think this component work fine.
aftes this conclusion, y read voltage in a LTC3407, in the same place of picture of Go4IT post, anh i have same voltages, but after little time; the voltage down to 0,xx in both places.
I replace the ram memory, only one slot of memory, in the same side of voltage regulator and my unit START!!!!
My next step is try to put focus/kuga firmware...
Kuga MK1 owner
