disassembling travelpilot fx firmware system.elf file
oscarboiro
Re: disassembling travelpilot fx firmware system.elf file
Post by oscarboiro »
tomy75 wrote: 07 Feb 2020, 17:21 Can you set windows to english?
You working with win7 or win10?
Hello, i have windows 7 in the laptop of screenshot, and have two Panasonic cf-19 with windows 7 and 10, but don’t have any apple computer.
I try to change settings of lenguaje but after restart not change, only the keyboard, any suggestion to change leguaje? I don’t want format hard disc.
I install driver following Go4IT Instructions, now without specific software I don’t can try any more.
Kuga MK1 owner
hanssi
Starter
Post by hanssi »
I have installed driver via zadig.
Then is possibility to update driver direct in W10.
Are this settings correct?
hanssi
Starter
Post by hanssi »
Oscar, you must download and install EN language pack.
I found something that may be helpfull here, you need to try: http://filestore.to/?d=R5IVIXKGER (ZIP pw is "boschnerd"). It seems to be a USB-Downloader with full sourcecode. Maybe some of our Software-engineers here can get from the sources how it should work.
