ronald0001
- Active member
i take the dump.bin of my convers and also create a bin fom the generated vbf of ch
is see that the numbers of pictures are different...is this normal
left the dump of my c+ and rigth is the generated vbf of ch (also only binary part) and when i create logo logo looks very nice after loading as bin or as vbf in ch it looks like this ok now its blue like it should be but qual is very bad
Try to change theme to "Theme 1 M"
P.S. Nice picture! Maybe we need to create a contest for the best logo?
Not native English speaker
I'm not sure if it's a bug but as you asked us to tell of any problems here is, logos not at 120000 I used your new feature I may not be doing it right?
Also when comparing with another flash and select in file BGR logo not showing correctly
Left logo xp is used with your new feature logo on the right is the other way of making logos
DGAlexandru
- Pro
In file BGR works only for VBF/BIN File1 and only when you have one file opened. After you open second image it won't update any more.
ronald0001
- Active member
sometimes....i had the same problem...after changin offsets and add picture....after 3 or 4 times reopen ch it works....
here a little bootanimation...but i forgot one pic to replace
https://youtu.be/RvSzw8GRe_E
It's windows...ronald0001 wrote: ↑10 Jan 2020, 00:30
Tourist
DGAlexandru
- Pro
The offset you have to enter is the address of the flash (main or extended) where you find the start of the frame that describes that image. It is the same one that the tool writes on the Offset4Main column.
This option is used mainly when you know that there is an image described at that offset address, but the tool wasn't able to detect or when you analyse a function from Main Flash in a debugger or a disassembling program and want to see what images it uses (from main or extended flash).
Does the new wallpaper put logo before 120000
