paxtonix
Post by paxtonix »
Artist wrote: 29 Dec 2019, 23:02 I tried to visit Conversmod.de and I found all logos in the right size and in excellent quality without losing colors!
Logos are downloadable and are already in resolution 400x198. Just to compare ...
On PC they look good - the implementation looks like shit.
changing the logo is not difficult - but the selection of the color palette is a bit difficult, there are some material on the RLE encoding in web
example
https://www.nxp.com/docs/en/fact-sheet/ ... RLE-FS.pdf
Tourist
RLE is only the compression and has no influence on how the image looks like. The algo was already discovered by Ursadon and me and documented here. What you refering to NXP is something different.
Because the display is set to only use 256 different colors at once, the dynamic range of an image is limited. The firmware does not make use of the shade-feature of the EPSON controller, which could apply up to 64 shades for each color.
So you load the image into, e.g. IrfanView and convert from RGB to 8 bit indexed-color-palette. This is what you get lateron.
Because of this fact images with high contrast will not look good.
Gwe89
Post by Gwe89 »
Tbh I dont think the quality is to bad
phx-
Starter
Post by phx- »
so amazing work, im bit sad because i cant help coz i dont understand this so much,still reading topics and learning and trying use something... but i must ask, can i get pw of 7zip of convers hackers.exe ? :) i using method try-fail,try-burn ipc lol :lol:
never give up !
User avatar
Stevebe
Post by Stevebe »
Just had to make some thing different for my convers
Probably only guitarist will appreciate this one
Rock on 2020 H.N.Y
Digimod
DGAlexandru
Post by DGAlexandru »
Convers+ IMG Hacker v1.1.0
Fixes: .. hmm.. many or none.. don't remember as I did a lot of work with it :roll:
Added:
Possibility to load a RAW Image and use the "Themes" to see how it looks. A RAW image is an image in RGB8 format that is not compressed (RLE), like the way they are before sending them to the display controller (EPSON). This comes in handy when dumping the memory range from DMA address space that is reserved for image creation.
Appearance:
New UI with menus and icons, as there were starting to be too many - this is why I jumped the version from v1.0.1 to v1.1.0. Initially the v1.1 release was supposed to come with the migration of "Convert Image" from external window to main window, but the "RAW image load" feature was needed.
paxtonix
Post by paxtonix »
Stevebe wrote: 01 Jan 2020, 00:21 Probably only guitarist will appreciate this one
Rock on 2020 H.N.Y
guitar open ceremony on c+ chellange :lol:
Tourist
Gwe89
Post by Gwe89 »
User avatar
Ursadon
Post by Ursadon »
DGAlexandru wrote: 22 Dec 2019, 21:32 Ursadon, I hope you're OK with all of this. :roll:
If you want I can give you the sources for all of this.
I am glad that my achievements did not go unnoticed :)
Since you could figure out my ugly code, we can join forces and develop together. Github?
Not native English speaker :cry:
tomy75
Post by tomy75 »
Hello Ursadon,
I'm looking forward to working together
Ursadon wrote: 04 Jan 2020, 11:28
