Gwe89
Post by Gwe89 »
Gwe89 wrote: 27 Dec 2019, 10:22 I changed 30 12 00 0C and 30 12 00 00
To 30 12 04 0C and 30 12 04 00 and works logos not the best but has worked
used image with swapped RGB TO BGR
DGAlexandru
Post by DGAlexandru »
ConversHacker V1.0.0
A lot of fixes, many still to be resolved.
Soon new engine for Converting Image (I hope better than the current one, in order to have better graphics).
New Features:
  1. You can load 2 VBF or BIN files and compare the images they contain and at which address they are known to the Main Firmware :idea: :roll:
  2. You will see 2 buttons that are not yet enabled - Load Main and also Save Main - as the logic behind is not yet bullet-proof. With this option you'll be able to swap IMG offsets that are written in Main FW for VBF / BIN file1 to the ones of VBF / BIN file2 - this will allow you to use VBF / BIN file2 in pair with the modified Main FW. This is something that the first modder of Convers (m0 tr al) should have done for PreFaceLift and MiddleFaceLift Main FW in order to use External Flash VBF of FaceLift and not copy the Icons in Main Flash - or at least this is how I would have done :) The scope here is to remove all the extra needed images from Main FW and have them in Extended Flash - how it's done for Chinese Convers+.
Gwe89
Post by Gwe89 »
One for the kids
tomy75
Post by tomy75 »
do you know this?
Gwe89
Post by Gwe89 »
tomy75 wrote: 28 Dec 2019, 21:15 do you know this?
Would be nice to get hold of that but m0tral will definitely not share this
DGAlexandru
Now I do :lol:
@All
If we collaborate (share knowledge, tools, drop the "he said that / he did that", invest time) and put our heads together we can easily get there and for sure beyond :!: :idea:
Convers+ IMG Hacker 1.0.1
Minor fixes:
Previous version had a redesign in the way it opens images which wasn't fully tested with Main FW so it didn't work because of the 0x5000 bytes gap between VBF file and BIN/RAW main flash. The same redesign also broke image viewing for generated VBF with the same tool :)
Adding the possibility to open a second VBF / BIN file created problems if it had less images than first file because of the missing offset from the corresponding rows. Now if the offset is 0x00 it will not try to open the image - so the tool won't crash any more. :roll:
Added:
Status bar with info about what's going on - mainly feedback from pressed buttons :)
DGAlexandru wrote: 29 Dec 2019, 00:57 If we collaborate (share knowledge, tools, drop the "he said that / he did that", invest time) and put our heads together we can easily get there and for sure beyond :!: :idea:
I totally agree with you! :D
It seems that there are some skills on different levels, but that's fine!
paxtonix
Post by paxtonix »
@DGAlexandru I was away for a while, and I see you were not bored, at all ;) , good work. keep it up.
I have to catch up with what happened during the X-MAS holidays -
I saw something interesting in other thread as well. :D need to check it out too.. ;)
Tourist
vodafone
Post by vodafone »
Gwe89 wrote: 27 Dec 2019, 12:39
20191227_120602.jpgused image with swapped RGB TO BGR
Good work ;)
I am glad that I managed to somehow help
better future with childrens
Artist
Post by Artist »
I tried to visit Conversmod.de and I found all logos in the right size and in excellent quality without losing colors!
Logos are downloadable and are already in resolution 400x198. Just to compare ...
https://www.conversmod.de/index.php?page=edit_logo
P.S: I tried to convert the logo to another format, eg. .jpeg and you still saw the loss!
Therefore it is necessary to use lossless formats ...
