Hidden menu: Pointer placement mode
Disassemble Convers+ firmware 7M2T-14C026-AG using IDA Pro
User avatar
Ursadon
Re: TODO: Pointer placement mode
Post by Ursadon »
Go4IT wrote: 23 Dec 2019, 21:08 Finally, i found the routine above in my 7M2T-14C026 firmware at 0x590A:
Code: Select all
void __fastcall sub_590A(int a1)
  int v1; // r0
  v1 = sub_5892(a1);
  if ( sub_1BCB0(v1) )
    sub_AD04();
    if ( (unsigned int)(sub_AD3C(9) - 180) <= 75 )
      if ( sub_1BCF2() )
        sub_1A858();
        sub_5860(94);
      else
        sub_1BBCC();
        sub_5860(93);
  JUMPOUT(&loc_588C);
Your offsets is wrong.
To enter to debug mode you need to:
1. Reset via reset pin
2. short-circuit right button ladder contacts
3, pull PE12 up
it remains only to find out what this contact is connected with
Not native English speaker :cry:
Re: [MK4] TODO: Pointer placement mode
What offset is wrong? I loaded Firmware from 0x0000. I think the position varies from type of firmware.
What do you think PE12 is used for?
Hmm, i found the menu in the pristine AG version of preFL firmware, can set PC to get menu drawn but can't get it stable as it directly leads into a reset. I guess it's watchdog which makes trouble. By i for shure use the wrong entry point.
User avatar
Stevebe
Post by Stevebe »
Ursadon wrote: 09 Mar 2020, 09:57
3, pull PE12 up
pull point PE12 can be found on this via
Digimod
Nice picts, but what will you tell us? Where PE12 is?
