How to desolder/solder an TSOP chip
All hardware topics
Re: How to desolder/solder an TSOP chip
That happens to me once also. Yes, the missing pads are N.C. pins.
If you've blown away some parts, you should throttle the air to 50%.
Try to use a small nozzle and only heat up where you need.
Also do not overdue, keep distance of 3-5 cm.
