Inspect FX PIN-Code
latigido
Re: Inspect FX PIN-Code
Post by latigido »
Hello,
After research of FX firmware result is as follows:
There is no pin code calculation algorithm inside firmware.
Given pin code is just compared against stored in eprom part.
I have a different understanding. It must be somehow calculated and obfuscated with the serialnumber. Where did you see a compare with what eprom data? The eprom of the board is not connected with the OMAP but the V850. An in earlier posts i already proofed that the contents of it is not relevant in any way and would be rebuild each full poweron.
