Repair FX, NX satnav units not starting anymore
oscarboiro
Re: Repair FX, NX satnav units not starting anymore
Post by oscarboiro »
Stevebe wrote: 03 Dec 2019, 18:04
oscarboiro wrote: 03 Dec 2019, 11:01
DGAlexandru wrote: 03 Dec 2019, 10:29 Put it in freezer, in a bag, after you changed the RAMs and let it cood down to room temperature, for 5 minutes then get it out and apply power to it.
It's a good test to see if all the contacts are good and also if the RAMs are good too.
I try it and work fine after remove from freezer, thanks!!
hi i have a NX with the Ram problem but i have not been lucky to find any good chips anyone have any to sell or point me in the right direction
Hi Steve, i wrote you on messenger the link where i bought the RAM
Kuga MK1 owner
Yes, i do this the same way (always in a plastic bag) using a deep-freezer, down to -25 degrees for two hours. I call this "climate test", but i must admit it was not certified by Greta! :lol:
oscarboiro wrote: 03 Dec 2019, 10:13 Thanks to Go4IT to help me in another Fx to replace the memory, now i reply the same steps with good results!
Great job, oscarboiro, makes me glad my tipps are helpfull :) Removing the RAM chips with the "Hot-Air and wire-pull" method is really easy. Only thing to keep in mind is to only put smooth force on pulling to void ripping off the pads.
Stevebe wrote: 03 Dec 2019, 18:04 hi i have a NX with the Ram problem but i have not been lucky to find any good chips anyone have any to sell or point me in the right direction
THAT is a real issue! Most chips are fake, and in the end they all came from China... :?
I have some real genuine ones left, as i bought a small stock ammount (the last ones from a depod) from a trusted source in USA a view years ago. Shure Bosch (aka Blaupunkt) have some in their stock, but won't sell them seperately. Some day a Bosch employee contacted my to repair his radio and he had the ability to get a pair from an internal department. But he was not able to gain more...
I also tried several China goods, but they all failed. Most of them right after soldering but even if they seem to run in first, the "climate test" killed the all.
As i get devices to repair which where already repaired before, i found the some "smart" repair services put compatible chips, which are usually used on PC RAM banks into it. Shure those chips are not build for those extreme environments like a car and will also fail if it's getting colder...
But if it is any help to you Stevebe, i can't send you over two chips from my stock.
User avatar
Stevebe
Post by Stevebe »
Go4IT wrote: 04 Dec 2019, 06:20
THAT
Thanks I would appreciate that have you got my address
Digimod
User avatar
Stevebe
Post by Stevebe »
Just used a pair of cheap chips from China and so far passed all the heat tests.
Digimod
Artist
Post by Artist »
I bought more expensive chips and they were bad. Do you have a link to the store, I would try to order them ...
Thx
User avatar
Stevebe
Post by Stevebe »
Artist wrote: 18 Dec 2019, 06:28 I bought more expensive chips and they were bad. Do you have a link to the store, I would try to order them ...
Thx
https://www.aliexpress.com/item/3268360 ... d04196f28f
I have only tried 2 out of 20 chips. But it’s been in fridge overn and it’s now been on for 10 hours.
Seems ok but time will tell
Digimod
I wish you good luck old man, but you know that those where fakes, aren't you?
You will get two genuine from me these days and can compare the difference.
BUT, i won't say that there are no working chips out there, only that i didn't find any, and have bought at 5 different resellers and different markings until i gave up. So please go on trying. Finding some good source would be a great benefit because my small genuine depot is getting empty...
User avatar
Stevebe
Post by Stevebe »
Go4IT wrote: 18 Dec 2019, 11:53 I wish you good luck old man,
Did you manage to sort out a pair of chips. Unfortunately one of those cheeeeppp chips died,
It was worth a try, I have found some that may be ok look right but until they arrive can’t be certain,
Ok on the video mod for MCA, I managed to pickup a secondhand unit with all fittings, and works so decided not to go ahead and update my none video
One.
Have good Newyear
Digimod
